Demoing Acrylic Panels? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 04-04-2014, 10:40 PM   #1
iminaquagmire's Avatar
Rewards Points: 338
I've got a bathroom to demo tomorrow and the shower has acrylic panels over the drywall for a surround. Ordinarily I would just sawzall it out but my sawzall is currently on loan to a family member. Has anybody tried to just break acrylic panels? They are a good 3/16" and not fiber reinforced as far as I can tell. I tried to peel them off but they must have troweled adhesive on the back and are firmly attached to the drywall. Will brute force do it or do I need to go get my sawzall back?
iminaquagmire is offline   Reply With Quote
Old 04-05-2014, 01:59 AM   #2
Rewards Points: 744
Worst case, cut the drywall with a utility knife, then pull the whole thing off the wall. I'd expect the drywall nails/screws will pull right through.
Seattle2k is offline   Reply With Quote
Old 04-05-2014, 04:46 AM   #3
DIY staff
Rewards Points: 7,174
If they won't pry off in one piece----use you skill saw --set the blade to the thickness of the panel--wear you goggles.
Old 04-05-2014, 07:45 AM   #4
AHH, SPANS!!!
Rewards Points: 1,166
just like O Mike mentioned do that, consider to turn the blade around backwards as that seems to work to not grab the material in the teeth of blade. I use the backwards blade for vinyl siding and it works. if you have a helper have them hold the shop vac at the saw exhaust to help catch the plasti dust
hand drive is offline   Reply With Quote
Old 04-05-2014, 08:33 AM   #5
kwikfishron's Avatar
Rewards Points: 594
I wouldn't even consider showing up for a demo without my Sawzall, whether I thought I needed it or not.
kwikfishron is online now   Reply With Quote
The Following User Says Thank You to kwikfishron For This Useful Post:
oh'mike (04-06-2014)
How to cut acrylic light diffuser panels theseeker Electrical 21 07-21-2014 06:01 AM
ACrylic panels in an exisitng screen porch tbreiding Building & Construction 1 02-08-2012 01:29 PM
Acrylic shower wall panels. sukhenkoi Kitchen & Bath Remodeling 5 02-18-2011 06:01 PM
Decorative acrylic cabinet door panels..... SandyK General DIY Discussions 1 02-20-2009 03:00 PM
