Old 03-05-2012, 12:38 AM   #1
Demo'ing 2X4 framing
I was removing a non-load bearing wall. I have removed drywall and now I want to remove the frame. I don't want to make 2X4 frame into pieces. I want to take that into one piece. I don't know I can reuse it or not, but I would like to save it, in case I can able to use it somewhere else.
So now the question is - how can I take this out ? It looks like it is bolted to slab.
Please see the pics.
http://i699.photobucket.com/albums/v...o/P1010062.jpg
http://i699.photobucket.com/albums/v...o/P1010061.jpg
http://i699.photobucket.com/albums/v...o/P1010060.jpg
http://i699.photobucket.com/albums/v...o/P1010059.jpg
cprao is offline   Reply With Quote
Old 03-05-2012, 12:54 AM   #2
Not going to happen and far more work then it's worth.
For one thing I'd bet if you measure them there differant length studs.
A slab floor is never perfectly flat.
Just use a maul and rap the sides of the studs to knock them off of the bottom plates and swing them out away from the top plate to get them free.
Those bottom plates are not bolted there powder shot into the slab floor. Your going to need a crow bar to pry them straight up off the slab.
A stud is only about $2.40 each so your not loosing much if they can not be reused.
Willie T (03-05-2012)
Old 03-05-2012, 05:05 AM   #3
Disabled wood vet
titanoman's Avatar
Sawsall whatever nails are holding the top of the wall in place, then lean the whole wall over.
The anchors in the floor may or may not come out.
titanoman is offline   Reply With Quote
Old 03-05-2012, 06:03 AM   #4
Super Moderator
Good luck---I have never seen a door opening big enough to get a wall section into or out of a room.
kj6887 (03-05-2012)
pocket hole jointery and cabinet screws for framing newbymodeler Carpentry 29 03-07-2013 04:17 PM
Tiling prior to building kitchen island framing? 444bullett Flooring 8 08-29-2011 10:12 AM
Any opinions on panelized framing? TitaniumVT Building & Construction 5 12-29-2009 02:56 PM
Framing for drywall under Spiral staircase clemon03 Drywall & Plaster 6 07-17-2009 04:49 PM
Framing a 16 foot high wall for shop pranderson Building & Construction 10 01-01-2006 05:23 PM
