Delta Waterproofing Membrane - Building & Construction - DIY Chatroom Home Improvement Forum
Old 03-29-2008, 04:47 PM   #1
Delta waterproofing membrane
Anyone have any experience using Delta MS waterproofing membrane to waterproof a concrete foundation wall? I'm considering how to waterproof the below grade foundation and was introduced to this product, but would like to hear from others who've used it....
thanks
RINAIL is offline   Reply With Quote
Old 03-30-2008, 07:11 AM   #2
conc repr & dec conc
Send a message via AIM to dec-conc-artisan Send a message via Yahoo to dec-conc-artisan
we used similar products,,,
tho not this particular brand,,, our sys always incl a troweled-on mastic 1st, then 6mil sheeting, then dimple board,,, used to get this stuff from ferguson supply but sonneborn also has it along w/many others,,, suggest you also incorporate a toe drain leading to daylight for gravity drainage.
dec-conc-artisan is offline   Reply With Quote
Old 03-30-2008, 09:52 AM   #3
ICF Construction
I have used it for years, dimple boards are great products but not the whole product, I would use a peel and stick on the ICF wall prior to dimple board. Peel and stick works on pretty much anything.
Chris
Chris Johnson is offline   Reply With Quote
Delta table saw blade guard problem RDS Tools 7 03-07-2008 03:29 PM
roof leak and EPDM membrane dbai Roofing/Siding 8 10-28-2007 05:16 PM
Shower membrane mc52 Building & Construction 2 01-27-2007 09:59 PM
