Old 06-04-2008, 01:28 PM   #1
Deffinition of a floating slab
I am searching for an accurate definition of a floating slab and the benifits of having one
Cory Groft is offline   Reply With Quote
Old 06-04-2008, 01:52 PM   #2
concretemasonry's Avatar
What are you building? Since you want an accurate definition the specific use and conditions permit similare slabs that are not exactly "floating", but are generally called floating.
A true "floating slab" example would be a garage slab the is poured between stem walls. It is not attached to the stem walls and is supported by the compacted soil beneath it.
The advantages are less of a tendancy to crack since the edges are not tied and the thickness and reinforcement can be less that a typical structural slab.
A basement floor is very similar, but not exactly the same. Much thicker slabs like slab foundations and post-teneioned slabs are also similar, since the soil supports the slab.
concretemasonry is offline   Reply With Quote
Old 06-04-2008, 02:14 PM   #3
Lets use the true definition, would a product that is 3/8" thick continuous vapor barrier acting as a cushion like thin foam products now being used under wood floors have a benefit? The product is called Slab shield.
Old 06-04-2008, 02:50 PM   #4
You would have to check with the flooring manufacturer to see that the requirements are the materials to use under a wood floor. This will affect any flooring material guarantees.
The term "vapor barrier", which is more correctly referred to as a "vapor retarder" depends on the material AND the thickness.
Old 06-04-2008, 03:11 PM   #5
I apologize I didn't phrase my question clearly. The question is using the flexible foam product under concrete. I know that improves cure time, radon and termite barriers.
What underlayment for floating floor on concrete slab? digexpressions Flooring 9 11-09-2011 08:22 PM
Monolithic or floating slab ? pushkins Building & Construction 2 02-26-2008 11:09 PM
Basement Framing - Floating Slab JackOfAllTrades Building & Construction 8 02-05-2008 04:20 PM
Floating Slab JackOfAllTrades Building & Construction 1 01-26-2008 12:07 AM
Floating Wood Sub-Floor over slab? Stargazer Building & Construction 8 11-25-2007 08:41 AM
