Old 07-04-2011, 10:51 PM   #1
Default Making a doorway bigger
Hello, I bought a new refrigerator and it won't fit through the kitchen doorway. I need to cut an inch off the doorway so the fridge will fit. There is no door or jam,it is just a doorway. I would appreciate any ideas on how to do this including what the best tools would be etc..even with the doors off it wont fit
goku8586 is offline   Reply With Quote
Old 07-04-2011, 11:02 PM   #2
MikeKy55's Avatar
I would first look to see if you can't remove the door on the fridg. That would be a lot less work.
MikeKy55 is offline   Reply With Quote
Old 07-05-2011, 01:12 AM   #3
With the doors off it wont fit
Old 07-05-2011, 01:27 AM   #4
Old 07-05-2011, 07:27 AM   #5
If you cut the drywall off the frame (careful with a utility knife to cut through multiple times) you should gain about 1" (assuming 1/2" drywall on the insides of the doorway opening). It may fit through.
After, reinstall drywall and Bob's your uncle.
bob22 is offline   Reply With Quote
Old 07-05-2011, 07:40 AM   #6
Super Moderator
Post a picture---there has to be a 'wrap' on the opening---drywall or wood casing---drywall adds 1" --
take a hammer and tap on the corner --the mud will fall off---exposing a metal corner bead---remove that--then remove the drywall.
If it's got wood trim---carefully cut the caulking--pull the trim--then remove the wood jamb.
Old 07-05-2011, 08:29 AM   #7
Did you try taking the door off first?
Ron
B. Franklin 1759
Old 07-05-2011, 09:09 AM   #8
Super Moderator
Goku---stop duplicating this post----You are making a lot of work for us moderators.
I loose most of the posts that I have to merge together----
adding bifold doors to a 59" doorway diy'er on LI Remodeling 14 11-12-2010 09:08 AM
Make a bigger doorway in a load bearing wall andiebynature Building & Construction 0 05-23-2010 12:28 PM
Raising Doorway Height (load bearing?) treefrog Building & Construction 6 02-25-2008 10:11 PM
Making a doorway into a display unit Susie Carpentry 2 10-13-2006 08:37 PM
