Decks: Hurricane Tie Or Toe Nail Joists? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 03-01-2012, 09:55 AM   #1
Rewards Points: 43
Decks: Hurricane Tie or toe nail joists?
For securing your joists that land over beams, is it okay to toe nail the beams in from both sides, or is it best to use a hurricane tie like the strong-tie H2.5?
My deck has two levels, 12" off grade at highest point, and 24" for second level.
Quicksmoke is offline   Reply With Quote
Old 03-01-2012, 10:08 AM   #2
robertcdf's Avatar
Prefer the positive connection of H2.5 or similar.
robertcdf is offline   Reply With Quote
Old 03-01-2012, 04:40 PM   #3
Residential Designer
AndyGump's Avatar
Rewards Points: 662
Send a message via Skype™ to AndyGump
Do you live in a hurricane prone area?
Andy.
Residential Drafter/Designer
www.draftinginoc.com
AndyGump is offline   Reply With Quote
Old 03-01-2012, 06:20 PM   #4
Civil Engineer
Rewards Points: 4,564
Simpson ties are very good, I recommend them over toenails any day.
Daniel Holzman is online now   Reply With Quote
Old 03-01-2012, 08:57 PM   #5
Framing Contractor
I've never heard of or seen hurricane ties used on floor joists before. Is this code somewhere?
Joe Carola
Joe Carola is offline   Reply With Quote
Old 03-01-2012, 09:20 PM   #6
AndyGump's Avatar
Rewards Points: 662
Hmm...good point Joe, I was for some reason assuming that this was for a deck but he says nothing of kind.
I should know better than to assume.
Andy.
Old 03-01-2012, 10:13 PM   #7
Civil Engineer
Quicksmoke says this is a deck, see his first post. See Figure 6 of the Prescriptive Guide 2006 edition for a picture of a joist to beam connection using a hurricane clip. Also shows use of toenails as an alternative, I simply prefer the clip.
Old 03-01-2012, 10:35 PM   #8
Framing Contractor
Joists are always toenailed to top plates never using hurricane ties. Why would they need them for a beam? Just curious....don't see the reason. Every single house...addition....deck. I've ever built ....joists get toenailed. Never seen or heard of this before on any forum either.
Joe Carola
Old 03-01-2012, 10:42 PM   #9
robertcdf's Avatar
(2) 16 D nails, (3) 8D nails or a metal hardware connection is required for decks with dropped beams. If you're building a deck correctly (flashing the tops of the beams) then the less penetrations through the flashing the better, so a H2.5 or similar is a good option, they usually run $.50 for a ZMAX rated one. over 16 joists its only $8.
Old 03-01-2012, 11:01 PM   #10
Registered User
Rewards Points: 5,204
Page 7, as Daniel said for that Code: "toenails only used if the deck is attached to the house with a ledger".....
Gary
P.S. The link: http://www.awc.org/Publications/DCA/DCA6/DCA6-09.pdf
Old 03-02-2012, 10:10 PM   #11
Rewards Points: 43
Wow! Didn't know I even had an semi-interesting question, lol!
Just little more info, I'm located in central jersey, so definately not hurricane prone. The deck I'll be building is free standing from the house using a combo of dropped and flush beams in order to use 2x8's and keep off the ground.
I see both methods recommened, just wasn't sure which was really preferred, or a good point brought up, per code.
Options for bridging floor joists. atxjoe Building & Construction 1 02-10-2011 10:31 PM
Bubba's been here. Repairing sagging rim/floor joists. MattFels Building & Construction 7 02-09-2011 06:28 PM
Floor Joists of different sizes HooKooDooKu Drywall & Plaster 7 02-04-2010 06:43 PM
Replacing Termite Damaged Sill, Joists, and Girders bd_dc Building & Construction 0 02-02-2010 12:21 AM
Spacing of ceiling joists Pineconeman Building & Construction 3 05-14-2005 12:16 AM
