Decks - Building & Construction - DIY Chatroom Home Improvement Forum
Old 07-27-2012, 09:09 AM   #1
decks
Does anyone have a guess on how much a foundation mite settle. I have 4 12" round concrete foundations 42" deep with 6x6 post 2x12 beams and 2x10 joist whith a hot tub going on it about 3,000 lb. and I'am wondering how much this might settle?
gco8888 is offline   Reply With Quote
Old 07-27-2012, 09:26 AM   #2
robertcdf's Avatar
If done properly... NONE, a foundation should NOT settle.
robertcdf is offline   Reply With Quote
The Following 2 Users Say Thank You to robertcdf For This Useful Post:
GCO88 (07-27-2012), mae-ling (07-27-2012)
Old 07-27-2012, 10:14 AM   #3
Civil Engineer
Rewards Points: 4,514
Robertcdf is correct, a properly designed and installed foundation will compress slightly when loaded (at least the wooden post will compress slightly), but the concrete pier itself should have virtually unmeasurable settlement. Of course, if the foundation is not properly designed, or is improperly installed, substantial settlement can occur. There is an entire industry devoted to repair of improperly built foundations.
The Following User Says Thank You to Daniel Holzman For This Useful Post:
GCO88 (07-27-2012)
Old 07-28-2012, 05:03 PM   #4
GBrackins's Avatar
Rewards Points: 2,108
If I understand correctly this is an existing deck you are looking to put a hot tub on? the foundation must be designed based upon the loads it must support and the bearing capacity of your soil. If your footings are undersized then your deck will settle. If your deck is existing and it was not designed for a hot tub you should have someone local that is knowledgeable (architect, professional engineer or contractor) come to your site and perform an evaluation before installing a hot tub. The reason I say local is they can perform a better evaluation than someone on an online forum because they can observe all existing conditions (including excavating down to the bottom of the foundation to determine the size of the footing and the type of soil).
if your deck is at ground level (or slightly above the ground) you may want to consider putting in a concrete slab to install your hot tub on.
Good luck!
Gary
"You get what you pay for, and sometimes free costs more!"
GBrackins is offline   Reply With Quote
Decks: Staining versus Sealing? rszymko Painting 7 05-29-2012 07:46 PM
County has no building codes for decks?? kwerk Building & Construction 14 09-15-2010 12:13 AM
Troy Built engine:what mower decks will fit? boone722 Tools 3 09-21-2008 10:23 PM
Decks -Beams vs Posts sandyman720 Building & Construction 4 04-13-2008 10:30 AM
decks and patios dave_kcmo Site Help and Suggestions 0 10-23-2005 11:16 PM
