Old 05-15-2012, 07:34 PM   #1
decks
how do i attach a 2x12 to a 6x6 for a deck
Michael.sparky is offline   Reply With Quote
Old 05-15-2012, 09:34 PM   #2
robertcdf's Avatar
decks
Originally Posted by Jeeps View Post
As I gaze in to my crystal ball a smokey image is appearing in it. It is the OP attempting to fasten a 2x12 joist band to his 6x6 upright support posts. ...
Wait, he has nailed the 2x12 to the 6x6 post but for a better support, he is now drilling though the 2x12 and all the way though the 6x6 with a 1/2 x 12 inch long spade wood or metal bit and is installing 1/2 x 10 inch long galvanized carriage bolts to secure the 2x12 to the 6x6 post. That is all I am getting now, the image is fading fast...........................
And that method is not an acceptable attachment method for a deck beam... Might want to get a new crystal ball with updated codes...
robertcdf is offline   Reply With Quote
Old 05-15-2012, 11:28 PM   #3
Moderator
decks
Welcome to the forum!
If the 2x12 is part of a built-up beam, compare it to this: http://www.awc.org/Publications/DCA/DCA6/DCA6-09.pdf
It has your notches, fasteners, spans, hardware, etc. for a safe deck. If different than listed, describe what you are doing in more detail and pictures always help: How to attach a photo to a post
Gary
Clothes taking longer to dry?
Old 05-16-2012, 10:15 PM   #4
DIY or die !
decks
Always sandwich the 2x12''s, This compression is what gives them added stability. You can either notch the 6x6 at the top and then carriage bolt the 2x12s in through the side, Or you can go with 3 2x12''s right ontop of the colum, and use a bracket specificly designed for it.
lewisthepilgrim is offline   Reply With Quote
Old 05-18-2012, 12:40 AM   #5
decks
check these fasteners out
http://www.fastenmaster.com/index.html
be careful my advice only comes from general knowledge i know about the 4 rules it takes to plumb and they are
1 poop needs to flow down hill. 2 hot on left cold on right
3 i get a pay check on Mondays 4 do not chew finger nails at or after work.
jaydevries is offline   Reply With Quote
bolts for decks anibita Building & Construction 5 05-09-2012 06:50 PM
What is the best fastener scheme for outdoor decks in high humidity areas? Chris Crawford Building & Construction 0 12-22-2011 02:45 PM
Troy Built engine:what mower decks will fit? boone722 Tools 3 09-21-2008 10:23 PM
decks and patios dave_kcmo Site Help and Suggestions 0 10-23-2005 11:16 PM
