Decking Selection - Building & Construction - DIY Chatroom Home Improvement Forum
Old 08-30-2011, 12:17 PM   #1
Rewards Points: 280
Decking Selection
Azek. Is it worth the money?
I'm reflooring my elevated deck. Azek Morado decking looks the best and matches the existing wall color. For those who install it or have had it installed, is the product worth the money?
Other questions:
Any know issues with Azek PVC decking that would change my mind?
Can the deck board be attached by screwing to the edges vs face nailing? Local building supply company is suggesting CAMO Hidden Deck Fastener system.
EDIT: I found a reference at both Azek and Camo that the Camo fastener is authorized for installing the deck boards.
Earnie is offline   Reply With Quote
Old 08-31-2011, 07:19 PM   #2
robertcdf's Avatar
Personally I don't like PVC boards so I usually recommend Fiberon Horizon or DuraLife Siesta (although duralife may be shaky right now due to a potential sale by it's parent company).
robertcdf is offline   Reply With Quote
Old 09-02-2011, 08:33 PM   #3
Rewards Points: 280
Robert,
Could you expand on why you don't like PVC?
While at the local building supply store, I picked up two product pamplets. One for Azek and one for Fiberon. I had never hear of Fiberon so I focused on Azek.
Nothing purchased yet so I'm open to recommendations.
Thanks.
Old 09-02-2011, 10:13 PM   #4
I'm getting my Azek deck done starting next week. I like the low maintenance aspect of it and it was only around 2k more than cedar. I'll let you know how everything goes after it's done.
djBern is offline   Reply With Quote
Old 09-03-2011, 06:47 AM   #5
Rewards Points: 280
Thanks. I'm interested in how the project turns out.
What color decking?
Are you also having railing installed? I was quoted Azek railing. Problem is, my deck is 10'x10'. Rail sections come in 6' lengths. That means I'll have 6' of wasted product @ $37.00 per foot. Over $200.00 in railing pieces for the landfill. I need another railing choice.
Old 09-03-2011, 07:58 AM   #6
What color decking?
I chose slate gray, I think it goes well with our brick color. We are going with cedar railings with black aluminum balusters. It should look something like this(but slate gray instead of brownstone):
Few more pics here: http://www.royaldecks.ca/photogaller...decks/deck1079
Old 09-03-2011, 08:36 AM   #7
Rewards Points: 280
Very nice. I like the contrast in colors on the rail.
Old 03-16-2012, 09:45 AM   #8
Been a while but I thought I'd follow up my post with some pics.
I started staining the lower posts in a similar gray shade because the wood & slate gray Azek contrasted too much. I'd eventually like to cover those lower posts with some stone veneer.
Old 03-16-2012, 10:28 PM   #9
Rewards Points: 626
it looks nice and all what is the cost per board foot? I just got back my Alaska Yellow cedar from the mill. I tracked that every step of the from log to lumber. And it was around total for what I did 4 dollars per board foot. my place smells so nice with that yellow cedar.
Nailbags is offline   Reply With Quote
Railing Selection with TimberTech Earthwoods Decking skinsfan44 Building & Construction 9 09-26-2013 08:44 AM
Trex decking LL1 General DIY Discussions 56 09-30-2011 09:55 PM
Deckmaster--will it work with 3/4" hardwood decking? jbeall Building & Construction 8 03-15-2011 09:05 AM
Trex Decking over Treated Decking retired2pa General DIY Discussions 6 12-15-2009 06:16 PM
installing plywood or backer board over decking gwags Building & Construction 6 04-02-2009 04:55 AM
