#1 |
Decking Screws - Color?
I got green decking screws (Phillips Square Drive II) from Lowes and they only had green. If I stain the deck with a semi transparent reddish color, will the screws look odd?
If so what is the best color to use with Pressure Treated decking? |
#2 |
Lic. Builder/GC/Remodeler
Go to a building supply house and look for these, and see if they are colored to match the way you plan on staining:
http://www.splitstop.com/
- Build Well - |
#3 |
How did I know you would be the 1st to reply?? Thanks!
Another quick ?. I got my joists from HD and decking from Lowes. I noticed that the 2x6 PT decking was much more greener that the 2x8 PT joists. Any ideas? |
#4 | |
Decking Screws - Color?Quote:
Get the hot dipped or stainless steel screws. |
#5 |
Moderator
Your ACQ decking will lose the bulk of its green color in a couple years. I'd opt for tan screws because they'll match once that happens.
#6 | |
One may also be drier than the other. Bottom line: I have ordered wood from different suppliers that look different as yours do. The difference is usually about the wood being drier than the other. Once they season, they should dry to the same color. If you plan on staining the deck the color that you said, do not use the green screws.
- Build Well - |
| Display Modes | |
| Trex decking | LL1 | General Discussion | 56 | 09-30-2011 10:55 PM |
| I can't get tapcon screws to tap into the concrete slab!? | Monty | Building & Construction | 24 | 08-07-2010 08:08 AM |
| Need help with wall & carpet color scheme | Cruciatus | Interior Decorating | 6 | 04-05-2008 02:50 PM |
| Screws vs Nails in Interior framing project | alexz | Building & Construction | 2 | 07-05-2006 06:58 AM |
| DECK decking nails vs screws ... | christian15213 | Building & Construction | 8 | 05-02-2005 08:51 PM |
