Decking Nails For Airgun? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 07-31-2009, 11:01 AM   #1
Rewards Points: 123
Decking nails for airgun?
I'm getting ready to put down some 5/4 decking. Do they make airgun nails designed for decking applications?
Thanks,
Chris
poolecw is offline   Reply With Quote
Old 07-31-2009, 12:32 PM   #2
Registered User
Termite's Avatar
You can get hot dipped galvanized gun nails for use in deck lumber but you'll end up regretting nailing your decking down...Trust me. You definitely want to use screws for a good installation.
If you opt for gun nails, go for hot dipped galvanized (not electro-plated galvanized). They'll just look like hell and will work themselves loose in time, but at least they won't decay in the treated lumber structure.
Old 07-31-2009, 01:23 PM   #3
Rewards Points: 123
Its not a deck for my home...I'm building a 12' x 20' raised platform that will be used as flooring for a dog kennel.
Thanks for the info!
Thanks,
Chris
Old 07-31-2009, 01:32 PM   #4
Jack of all trades
A Quick-Drive screw gun is almost just as fast as a nail gun. Plus you can stand up and fasten the deck boards, not as hard on the back.
wvwirenut is offline   Reply With Quote
Trex decking LL1 General DIY Discussions 56 09-30-2011 10:55 PM
Forgot to use galvanized nails... healeypd Building & Construction 8 05-12-2009 10:10 AM
What nails to use? 2x4 framing, osb sheathing jw15842 Carpentry 6 09-08-2008 11:31 PM
Which nails are right for the job? MIKEGOUGH1 Building & Construction 2 12-16-2006 11:54 AM
DECK decking nails vs screws ... christian15213 Building & Construction 8 05-02-2005 08:51 PM
