Deck Support ? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 07-11-2013, 03:16 PM   #1
n2omichael's Avatar
Rewards Points: 115
Deck support ?
Hey Guys
We recently moved our cottage onto a poured foundation/knee wall. As such out "front door" will be about 4ft above grade, we planned on building steps up to a deck that will run across the front of the cottage. It will be about 22ft by 10ft and eventually we are going to put a small (4x6) hot tub on the deck. I was wondering how I needed to modify my deck to support the tub? Would 4x4 do or do I need 6x6's for support?
I only have about 12" of dirt, then you hit SOLID limestone. So I had planned on drilling into the rock and putting rebar in the holes then filling sonotubes with concrete to anchor it, any thoughts?
n2omichael is offline   Reply With Quote
Old 07-11-2013, 06:09 PM   #2
Civil Engineer
Rewards Points: 4,680
If you live in an area where you need to build to code, you start by finding out which code you have to build to. Your local building inspector will be happy to help you understand what the code is for your area. If you don't need a permit, and don't need to follow code, you may still want to design following the Prescriptive Residential Wood Deck Construction Guide (http://www.awc.org/publications/dca/dca6/dca6-09.pdf).
That said, putting a hot tub on a deck is beyond the code, so the best way to design for the tub would be to determine the actual loads from the selected hot tub model, and check the joists, beams and posts for adequate capacity. It is impossible to size these elements without detailed knowledge about the deck design and geometry, and the size of the hot tub.
The Following 2 Users Say Thank You to Daniel Holzman For This Useful Post:
AndyGump (07-11-2013), roofingquotes (07-12-2013)
Old 07-11-2013, 07:12 PM   #3
Rewards Points: 13,444
A few other things to avoid future issues. That decks going to have to be at least 4" (may be more by local codes) below any door openings.
It's best to build this free standing so the siding will not be effected.
Never have the decking in contact with the side of the house.
A hot tub on a front deck, Hmm not the best plan.
Old 07-12-2013, 05:56 AM   #4
roofingquotes's Avatar
Its good that you know the local codes in building in your area. The first thing you should put in mind before building.
roofingquotes is offline   Reply With Quote
Old 07-12-2013, 02:19 PM   #5
n2omichael's Avatar
Rewards Points: 115
Deck is being built at my cottage on an Island, to say by laws and regulations are "flexible" would be an enormous understanding, as compared to building in a subdivision or urban area. I suppose I could attempt to find a building inspector on the mainland and ask.
I was more interested in building ideas and structural ideas for the framing and supports, as for the hot tub, many people (including myself) have tubs on there BACK decks, so, I don't see the issue with having one on the front deck if built right.
I will talk to a local carpenter and see what he says, Thanks
Michael
Old 07-12-2013, 10:09 PM   #6
Msradell's Avatar
Rewards Points: 170
One good thing you have going for you is that you have rock that close to the surface. You could actually pour 4 sonotubes (fairly large diameter) that would come up to directly support the joists to support the hot tub. This would give an extremely strong support.
Msradell is online now   Reply With Quote
Old 07-14-2013, 06:48 PM   #7
n2omichael's Avatar
Rewards Points: 115
Yes, that's kinda what I was thinking, or even use metal I beam for a lentil under the hot tub. The tub itself is very small, especially by today's standards, it's technically a four person tub, but. Really 2 people is more accurate.
Appreciate the input! sonotubes are SO damn ugly, but, I can hide them with lattice or shrubs, or maybe an old decripet car, lol
Deck Spans and support positioning justme729 Building & Construction 5 01-19-2013 09:45 AM
Support columns for second story roof deck MugsynSax Building & Construction 3 10-05-2010 09:27 AM
8' x 12' deck how - many support posts needed shuanrit Landscaping & Lawn Care 5 07-09-2009 09:57 PM
Need help with a deck to support a new spa! kellymac Building & Construction 5 06-12-2008 12:32 AM
Deck to support spa handiandi Carpentry 3 07-03-2005 02:19 PM
