Deck Structure Question - Building & Construction - DIY Chatroom Home Improvement Forum
Old 06-13-2010, 02:50 PM   #1
Question
Deck structure question
I have a PT deck that is 16'x18'. One 16' edge is attached to the house, and the rest of the deck is supported by two 6x6 posts and a 6x6 beam about 15' from the house. The joists run from the house to the beam, and then extend over the beam.
Over the years (15), the beam has sagged in the middle. The two posts are in about 2' from each end of the beam, and the middle has sagged about 2-3". It's very visible from the bottom of the deck. It's not noticeable when you're standing on the deck.
I'm sure I could jack the middle of the beam up and insert a third post, but I'm thinking that the bend in the beam isn't just going to straighten out. After 15 years in the weather, the droop is permanent.
I could also jack up the end of the deck and replace the beam with another 6x6 or laminate three (or four) 2x6s into a new beam. This would also require me to replace the ledger board at the outside edge of the deck, since it must have sagged to match the beam.
Any thoughts? I'd like to replace the floor boards with composite at the same time, and the beam repair would be easier when the floor is off.
Rick
houseinthewoods is offline   Reply With Quote
Old 06-13-2010, 05:46 PM   #2
What size are the deck joists ?
Old 06-13-2010, 06:01 PM   #3
concretemasonry's Avatar
Rewards Points: 2,566
The ledger should not have deflected if it was attached to the house properly. If you can run a line of the ledger and find a deflection, you better look at ledger attachment since few are installed properly when it comes to moisture, weather, mold and rot.
Dick
concretemasonry is online now   Reply With Quote
Old 06-13-2010, 08:21 PM   #4
Registered User
Rewards Points: 4,912
You could add a new post and cut the beam there to circumvent the memory problem of the wood. Codes changed a lot in the last 15 years... Here is the new Deck Guild most Building Departments are following: http://www.lancova.com/deckinfo.pdf
It covers joist span, beam size and span, ledger attachment, footings, posts, etc. If you have any more questions that aren't listed there, ask away. http://www.ideas-for-deck-designs.co...ite_decks.html
Be safe, Gary
Old 06-13-2010, 10:07 PM   #5
2x8, 16"OC. The ledger board attached to the house is straight. The rim joist that runs along the end of the joists droops about the same as the beam.
Old 06-13-2010, 10:18 PM   #6
Ouch. My joist span is 11'6", longer than the current code specifies. Looks like the joists extend past the beam further than they should, too. The joists themselves are straight as arrows, no sagging at all.
Cutting the beam in the middle and adding a post there might be the best solution. Thanks!
Deck Question gmhammes Building & Construction 19 05-28-2010 11:34 AM
Ipe deck + clip question saskman72 Building & Construction 2 07-30-2009 04:03 PM
Help Please....Deck post question steve dowd Building & Construction 6 05-12-2009 11:04 PM
Deck Stair Question Uncle Larry Building & Construction 10 06-19-2008 08:08 PM
Two-Level Deck Post Question Melanie337 Carpentry 2 09-24-2007 12:34 AM
