Deck Stairs Width & Railing - Building & Construction - DIY Chatroom Home Improvement Forum
Old 11-07-2010, 09:38 PM   #1
Professional Wood Shafter
ryanh's Avatar
Rewards Points: 154
Deck Stairs width & Railing
Hello. I couldn't find any info in my deck permit book or any of my other books but how wide can deck stairs be before you need a railing in the center?
ryanh is offline   Reply With Quote
Old 11-09-2010, 10:07 PM   #2
Registered User
Rewards Points: 526
Not that I am aware of for residential, only the minimum:2009=
R311.7.1 Width. Stairways shall not be less than 36 inches (914 mm) in clear width at all points above the permitted handrail height and below the required headroom height. Handrails shall not project more than 4.5 inches (114 mm) on either side of the stairway and the minimum clear width of the stairway at and below the handrail height, including treads and landings, shall not be less than 311/2 inches (787 mm) where a handrail is installed on one side and 27 inches (698 mm) where handrails are provided on both sides.
Try locally.
Gary
Old 11-17-2010, 12:10 AM   #3
ryanh's Avatar
Rewards Points: 154
ya same rules as here. i'll just put one in the middle to be safe
Old 11-17-2010, 03:46 AM   #4
Framing Contractor
All you have to do is call the town and ask them.
Joe Carola
Joe Carola is offline   Reply With Quote
Deck Staining Nightmare steven994 Painting 7 06-14-2017 04:56 AM
Extending height of deck railing tntworks General DIY Discussions 4 03-11-2013 07:16 AM
Deck stairs at an angle Debjohnson67 Building & Construction 1 06-14-2010 09:07 PM
A couple of Deck railing and privacy fence/screen question EightmanVT Building & Construction 9 06-01-2010 08:03 PM
Building a new deck....and creative uses of granite scrap in outdoor living space Rhizzlebop Building & Construction 9 05-15-2009 11:17 AM
