Deck Stairs Over Existing Stone Retaining Wall Steps - Building & Construction - DIY Chatroom Home Improvement Forum
Old 04-30-2012, 04:46 PM   #1
Deck stairs over existing stone retaining wall steps
I have a deck that is being built outside of a walk out basement. The property slopes so there is a mortared natural stone retaining wall that the back of the house is on. The retained area goes out maybe 20 feet from the back of the house leading to a 2 or 3 foot high retaining wall which then steps down to the yard. The deck contractor is planning to build a wooden stair case that is basically right over those 3 stone steps; tucking them into the stone stairwell. Is this ok? Should I be very concerned about needing to repair the loose mortar in the future? The wall in general is in good shape, but over time, the mortar tends to come loose in some areas (mostly near the top layer of the wall).
joshg3p0 is offline   Reply With Quote
Old 04-30-2012, 08:10 PM   #2
robertcdf's Avatar
Can you attach a picture? If what he plans on doing is what I see in my head I would recommend against it, however I might be picturing it wrong.
robertcdf is offline   Reply With Quote
Old 04-30-2012, 09:04 PM   #3
I'll upload a pic shortly; what's your initial concern and I'll let you know if it applies.
Old 04-30-2012, 10:13 PM   #4
It's night here, so can't get a good picture but I did find this online. This is NOT my house, but the wall and steps are similar to what I have in the back yard, imagine a string of steps with railings floating above the stone wall steps connecting to a deck.
Old 05-01-2012, 09:47 AM   #5
Also want to note that it seems the 5 or 6 staircase would be pretty easy to remove if the wall was in need of any repairs.
Old 05-01-2012, 07:02 PM   #6
robertcdf's Avatar
So you would walk down wood stairs and then be walking down stone stairs? If this is the case the RISE/RUN MUST be identical to be code compliant (within 3/8" of each other) this might be kind of hard to do. I don't like that transition without a landing (min 36" long x width of the stairs).
Old 05-01-2012, 07:11 PM   #7
No you would just be walking down a wood staircase for the entire journey. It would end up covering the stone steps completely.
Old 05-01-2012, 07:23 PM   #8
Actual photos. Stairs would go down across front of upper deck than land and turn and go down covering stone steps.. Or you could keep walking straight and go on lower deck
Deck stairs over existing stone retaining wall steps-image-876511479.jpg   Deck stairs over existing stone retaining wall steps-image-4263549753.jpg   Deck stairs over existing stone retaining wall steps-image-1514380079.jpg
Old 05-01-2012, 07:31 PM   #9
robertcdf's Avatar
Ok, not what I was picturing in my mind. No problem in covering the stone steps. That cantilever is mighty large (too big) is he planning on adding more posts on that stair platform? (upper deck)
Old 05-01-2012, 07:43 PM   #10
I don't think so, we cut the preciously existing upper deck back 14 inches to avoid needing additional footings. I assume there will be some smaller support posts though. If its messed up, wouldn't it fail inspection?
Old 05-01-2012, 08:02 PM   #11
robertcdf's Avatar
It could be the perspective of the camera but it looks like a 6' cantilever and then stairs hanging off it as well, I've seen large cantilevers like that with a set of stairs hanging and they usually sag later.
Old 05-01-2012, 08:29 PM   #12
I think it's more like 4' out from the post including the staircase width.
Old 05-01-2012, 09:42 PM   #13
robertcdf's Avatar
As far as passing code... just because it meets code doesn't mean its quality. I've seen quite a bit of things where "code compliant" was inadequate in the real world.
Old 05-01-2012, 09:44 PM   #14
Ok... Well how does 4 foot cantilever sound to you?
Old 05-02-2012, 07:34 PM   #15
robertcdf's Avatar
To be honest... I'm not wild about it, I'm not wild about it WITHOUT hanging a heavy set of stairs off it, once you add the stairs in there is a lot more weight there. It will be fine for a couple years, but likely down the road it will begin to sag.
If I HAD to build it that way then I would make every joist that cantilevers 4' a double joist, and possibly the one with the stairs would be a triple.
BUT... that is me and the way I build.
I'm sure your contractor would hate me if you brought this up (much like I would not be happy if one of my customers said "this guy on the internet said...")
foundation walls to support a deck bubbler Building & Construction 1 04-12-2012 04:27 PM
Retaining wall combining concrete blocks and PT lumber JEL Landscaping & Lawn Care 1 04-06-2012 09:39 PM
dry stack natural stone retaining wall diy001 Landscaping & Lawn Care 17 06-20-2011 12:57 PM
Short Retaining Wall - Footer jkim8520 Landscaping & Lawn Care 3 06-03-2011 11:27 AM
Need help with wood retaining wall idesign2 Landscaping & Lawn Care 2 08-12-2010 05:29 PM
