-   -   Deck stairs over existing stone retaining wall steps (http://www.diychatroom.com/f19/deck-stairs-over-existing-stone-retaining-wall-steps-142150/)
joshg3p0 04-30-2012 03:46 PM
I have a deck that is being built outside of a walk out basement. The property slopes so there is a mortared natural stone retaining wall that the back of the house is on. The retained area goes out maybe 20 feet from the back of the house leading to a 2 or 3 foot high retaining wall which then steps down to the yard. The deck contractor is planning to build a wooden stair case that is basically right over those 3 stone steps; tucking them into the stone stairwell. Is this ok? Should I be very concerned about needing to repair the loose mortar in the future? The wall in general is in good shape, but over time, the mortar tends to come loose in some areas (mostly near the top layer of the wall).
robertcdf 04-30-2012 07:10 PM
Can you attach a picture? If what he plans on doing is what I see in my head I would recommend against it, however I might be picturing it wrong.
joshg3p0 04-30-2012 08:04 PM
I'll upload a pic shortly; what's your initial concern and I'll let you know if it applies.
joshg3p0 04-30-2012 09:13 PM
1 Attachment(s)
It's night here, so can't get a good picture but I did find this online. This is NOT my house, but the wall and steps are similar to what I have in the back yard, imagine a string of steps with railings floating above the stone wall steps connecting to a deck.
joshg3p0 05-01-2012 08:47 AM
Also want to note that it seems the 5 or 6 staircase would be pretty easy to remove if the wall was in need of any repairs.
robertcdf 05-01-2012 06:02 PM
So you would walk down wood stairs and then be walking down stone stairs? If this is the case the RISE/RUN MUST be identical to be code compliant (within 3/8" of each other) this might be kind of hard to do. I don't like that transition without a landing (min 36" long x width of the stairs).
joshg3p0 05-01-2012 06:11 PM
No you would just be walking down a wood staircase for the entire journey. It would end up covering the stone steps completely.
joshg3p0 05-01-2012 06:23 PM
3 Attachment(s)
Actual photos. Stairs would go down across front of upper deck than land and turn and go down covering stone steps.. Or you could keep walking straight and go on lower deck
robertcdf 05-01-2012 06:31 PM
Ok, not what I was picturing in my mind. No problem in covering the stone steps. That cantilever is mighty large (too big) is he planning on adding more posts on that stair platform? (upper deck)
joshg3p0 05-01-2012 06:43 PM
I don't think so, we cut the preciously existing upper deck back 14 inches to avoid needing additional footings. I assume there will be some smaller support posts though. If its messed up, wouldn't it fail inspection?
robertcdf 05-01-2012 07:02 PM
It could be the perspective of the camera but it looks like a 6' cantilever and then stairs hanging off it as well, I've seen large cantilevers like that with a set of stairs hanging and they usually sag later.
joshg3p0 05-01-2012 07:29 PM
I think it's more like 4' out from the post including the staircase width.
robertcdf 05-01-2012 08:42 PM
As far as passing code... just because it meets code doesn't mean its quality. I've seen quite a bit of things where "code compliant" was inadequate in the real world.
joshg3p0 05-01-2012 08:44 PM
Ok... Well how does 4 foot cantilever sound to you?
robertcdf 05-02-2012 06:34 PM
To be honest... I'm not wild about it, I'm not wild about it WITHOUT hanging a heavy set of stairs off it, once you add the stairs in there is a lot more weight there. It will be fine for a couple years, but likely down the road it will begin to sag.
If I HAD to build it that way then I would make every joist that cantilevers 4' a double joist, and possibly the one with the stairs would be a triple.
BUT... that is me and the way I build.
I'm sure your contractor would hate me if you brought this up (much like I would not be happy if one of my customers said "this guy on the internet said...")
