Deck Stairs, I'm Almost Finished With The Deck - Building & Construction - DIY Chatroom Home Improvement Forum
Old 07-03-2013, 11:05 AM   #1
deck stairs, i'm almost finished with the deck
ok i'm on my last phase of this project, building the deck stairs. my plan is to build a whole side of the deck as stairs that go down, but i don't know what lumber to buy.
i used a stair calculator to get the below numbers but i need help understanding them. i don;t know what size boards to buy.
total rise 54
target step height 7.25
tread thickness 1.5
tread depth 10.5
total number of steps 7
total number of tread 6
height of first step 6.21
height of typical step 7.71 in
postion of stringer on landing 9.21in
total run 63 in
madmilitia is offline   Reply With Quote
Old 07-03-2013, 11:32 AM   #2
Old School
Willie T's Avatar
Eight foot lengths should be fine.
Willie T
Old 07-03-2013, 11:39 AM   #3
so 2x10 x 8 foot
Old 07-03-2013, 12:22 PM   #4
Rewards Points: 636
2x12 if cutting saw tooth stringers
and 7.71 high steps is a little tall for me
"be careful at listening to just one persons advise" said me
"be careful at listening to just one persons advise" said myself
p.s. not all i say is a fact but not all i say is my opinion.
jaydevries is offline   Reply With Quote
Old 07-03-2013, 12:29 PM   #5
hmm ok well from the top of the deck to the ground is 54 inches what would you recommend.
Old 07-03-2013, 12:39 PM   #6
Old School
Willie T's Avatar
This is what your numbers called for.
This is using a 2x12... as you should.
But note that this will make your top floor the last step, with the stringers fastening well below the deck. The overall frame is where your top will meet.
Doing it this way, you could get by with 7 footers.
Willie T
Old 07-03-2013, 12:51 PM   #7
ok this is why i come here you guys are so good. ok from the top of the deck to the ground is 54 inchs, the joist that they strings will attach to is 12 inchs wide.
so the bottom of the joist to the ground is 42 inches.
so i guess my calculator is all off cause i used the top of the deck.
Old 07-03-2013, 12:56 PM   #8
Old School
Willie T's Avatar
If you can go another 10.5" on the run (total of 73.5"), I sure would. But then I happen to like having a step on the very top, not stepping down right off the deck. Just feels better to me.
And, 7.71 IS a bit tall. But if you shorten each rise any, you are also going to have to go longer with the run.... I think you would end up with something like 6-3/4" risers. and I think you would add 21 inches to the run. (This paragraph is just off the top of my head, so do the math yourself.)
Willie T
Old 07-03-2013, 01:06 PM   #9
Rewards Points: 636
54 to the top of deck to ground
7 inches is ideal step height so we divide by 7
54/7=7.714.... so that means if we round it up we have 8
54/8=6.75 so each step will be 6.75 tall
making the last step off the stringer to the deck counts as one of these steps so your stringer when cutting it will have 7 steps
know the first step you have to cut off the tread thickness or when you add the treads it would be 6.75+1.5=8.25
hopefully this makes sense to you
Old 07-03-2013, 01:11 PM   #10
Rewards Points: 636
i am also going off of that the 54 inches is where the last step lands on the ground not straight down from deck. due to it being rare that it is the same height 7 feet away from deck
Old 07-03-2013, 01:21 PM   #11
Old School
Willie T's Avatar
This would be close to ideal to me. (That bottom riser still might need some tweaking.... didn't want to get into 1/32's)
Willie T
Old 07-03-2013, 01:23 PM   #12
Rewards Points: 636
also to give something solid to hang stringers off of deck i add additional 2x8 or 10 under floor just to give the back stringer something to go against and to nail the stringer hanger to
http://www.decks.com/deckbuilding/St...ger_Attachment
Old 07-03-2013, 01:42 PM   #13
Old School
Willie T's Avatar
Here's both of them for comparison. (<CONTROL> + mouse wheel ..... will enlarge or shrink image, depending on which way you roll the wheel)
Willie T
Old 07-03-2013, 02:30 PM   #14
ok so with the step being 10.5 inch wide what would you use for treads? do they mak a 2x5 1/4
Old 07-03-2013, 02:34 PM   #15
Old School
Willie T's Avatar
Yes, but I'd use two 2x6's (with a typical deck gap between them) Watch the nosing overhang... try to keep it to 1".
I'm assuming you can get away without putting in riser opening coverings?
These were drawn anticipating 1.5 thick treads (pretty common on decks), but yes, you can buy 2" or 3", but much big $.
Willie T
Deck Stairs issue...... ryan5068 Carpentry 1 07-02-2013 04:44 AM
deck stairs Jeremy Hillary Boob, PhD Building & Construction 7 11-22-2011 05:01 PM
Simple Questions About Deck Stairs Briandl Building & Construction 4 08-04-2011 01:54 PM
Deck Stairs with landing ? BDestroyer8418 Carpentry 2 01-29-2011 12:20 PM
avoiding slippery deck stairs rln17 Painting 2 09-12-2008 01:42 AM
