Deck Stair Stringer Footings - Building & Construction - DIY Chatroom Home Improvement Forum
Old 05-18-2011, 03:24 PM   #1
deck stair stringer footings
As I am working on my deck design I keep coming back to how I want to secure my stair stringers at gound level. My deck design is going to include a full set of stairs on all sides, except for the side against my house. For the rest of the deck I am placing 4 ft deep footers in the ground, but I am unsure as to the best way to support the stringers on the side opposite of the deck (ground level). I don't want to use just the ground to support.
Should I place a concrete post at each stringer (would be alot since I have 47 stringers in total?
Should I place a concret post every X ft and run a beam between the posts that the stringers will sit on?
Thoughts and help is appreciated.
EPERRINGTON is offline   Reply With Quote
Old 05-18-2011, 05:07 PM   #2
In a little over my head
Rewards Points: 706
Are we talking about the end of the stringer where it reaches the ground? I just dug a rectangle, a little larger than the bottom step, about 4-6" deep. Filled with concrete and leveled it. Sloped just a bit so water wouldn't pool. The end of the tringer rests directly on it. If your stringers are so long that you feel the need to support midway, I'd just pour footings like the deck has and use a post to the bottom.
ratherbefishing is offline   Reply With Quote
Old 05-18-2011, 10:14 PM   #3
Registered User
Rewards Points: 4,924
Notice the maximum span for cut stringers for table 1 species in fig.28, and more than a pad is required when using a guardrail for the 200# side resistance per code (Fig. 33,34); http://www.awc.org/Publications/DCA/DCA6/DCA6-09.pdf
Gary
Deck Staining Nightmare steven994 Painting 6 04-06-2014 10:10 PM
new second story deck stair, platform question walt1122 Building & Construction 10 11-12-2010 10:52 AM
Proper sizing for deck footings stubits Building & Construction 14 02-11-2010 12:26 PM
Building a new deck....and creative uses of granite scrap in outdoor living space Rhizzlebop Building & Construction 9 05-15-2009 12:17 PM
Screwed up stair stringer (picture in thread) iMisspell Building & Construction 9 11-13-2008 11:49 AM
