Deck Stair Requirements - Building & Construction - DIY Chatroom Home Improvement Forum
Old 05-28-2008, 09:33 PM   #1
Rewards Points: 152
Hello,
My city building inspector tells me that for my deck stairs:
"Risers are 8 1/4 maximum and treads are 9" minimum must be equal. Cannot exceed between minimum and maximum deviation total."
Does this mean that if you have 2- 2x6 as treads (11 inches) that your risers have to be 11 inches? If this is so, then that is more than 8 1/4 max and it will not work.
Can someone make sense of this?
sandyman720 is offline   Reply With Quote
Old 05-28-2008, 09:59 PM   #2
Remodeler
MinConst's Avatar
This just states the risers must be within 1/4" of 8 1/4" MAX" (all the same) Your 11" treads are fine and have no bearing on the risers. As long as you use the 11" treads and keep all risers at 9" or within 1/4" deviation your all set.
A more comfortable riser is 7-7 1/2" but your code just states max as 8 1/4" so you can use from 7 - 8 1/4" risers.
Minichillo's Construction
I will never leave you hanging!
Web
One Man Shops
MinConst is offline   Reply With Quote
Old 05-29-2008, 09:57 AM   #3
Registered User
Termite's Avatar
The tread is what you step on, and is called "run". You're fine with two 2x6's.
The "rise" is the vertical measurement between treads, which is 8-1/4" maximum.
With rise and run, you can't have any two stairs with more that 1/4" variance in rise or 1/4" variance in run. Dimensional consistency!
That's an old code your city is using!
Old 05-29-2008, 12:49 PM   #4
47_47's Avatar
Rewards Points: 44
Just to clarify, tread width is from the riser to the nose. Run is from riser to riser, nose to nose or tread minus overhang. Rise is from top of tread to top of tread.
47_47 is offline   Reply With Quote
Old 05-30-2008, 08:26 AM   #5
47_47's Avatar
Rewards Points: 44
Here's a link to a free online stair calculator.
http://www.inspectusa.com/info/calc/...n_stringer.htm
Hope this helps
Old 06-01-2008, 11:36 AM   #6
remodeling pro
Like kctermite said, those are pretty old numbers by modern codes . I'd verify with the inspector again, maybe your locality still allows those high riser/narrow tread combinations on exterior decks/stairs. Most areas are now 7 3/4 max rise and 11 tread, and 3/16" deviation between steps.
troubleseeker is offline   Reply With Quote
Old 06-01-2008, 08:07 PM   #7
Registered User
Termite's Avatar
The current International Code is 7-3/4" max rise, 10" minimum run, and max 3/8" variance.
Deck Requirements? sandyman720 Building & Construction 5 01-08-2008 08:27 PM
The Bioswale, french drain, deck, drainage dilemma (long) seabright_sc Building & Construction 2 01-05-2008 04:37 PM
Deck at seasonal camp site... Spike99 Project Showcase 0 12-24-2007 04:09 PM
Roof used as a deck - what is a good approach rogersor Roofing/Siding 3 09-19-2007 02:05 PM
What size deck is 'good' for our situation? curls00 Carpentry 20 09-08-2007 08:12 PM
