Old 03-21-2008, 05:58 PM   #1
deck stair rail height code
Code for the top of deck railing where i live is between 32"-38" from deck. What would the code be for deck stair rail height since the height varies from front to back of step? I may have have a follow-up question depending on answer. Thanks (county offices are closed and I want to finish this deck, plus I'd rather ask them as few questions as possible)
ugabulldog is offline   Reply With Quote
Old 03-21-2008, 10:19 PM   #2
remodeling pro
Stair handrail heights are always measured at a plumb line from the front edge of the finished tread.
troubleseeker is offline   Reply With Quote
Old 03-21-2008, 10:45 PM   #3
I did a little more research and that is what I was thinking, I am assuming I need a minimum of 32" at the front tread. I will call inspector on Mon to make sure because I will have more work to do. My top step is even with the deck and the deck railing is 36". I can't tie into that without being way low- 27" at front of tread. I am thinking I should add another post at the front of the top step (even though it will be only 10" from the other post) and tie railing into that....btw my pickets attach to the band board on deck and outside stringer on steps.
Old 03-22-2008, 08:09 AM   #4
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
In my region: It's 34" from the tread nose (Front), to the top of the railing above it. We usually just do 35" to 36" to play it safe.
- Build Well -
Old 03-22-2008, 10:45 AM   #5
There are two things to consider. One is the Guard Rail height and the other is the Hand Rail height. Stairs require both. They are at different heights.
kgphoto is offline   Reply With Quote
Old 03-22-2008, 03:04 PM   #6
thanks all, i will be calling inspector on Mon. Better safe than sorry...... I have a solution in mind, mentioned earlier, and it shouldn't be too hard of a fix, not near as bad as tearing down steps which are already in place.
Extending height of deck railing tntworks General Discussion 4 03-11-2013 08:16 AM
Minimum Deck height? sandyman720 Building & Construction 16 01-30-2008 12:12 AM
Stair rail question shimmy25 Carpentry 8 12-28-2007 11:02 PM
code for determining retaining wall height mrdol General Discussion 2 11-08-2007 03:47 PM
Deck Height w/out step DLP600 Building & Construction 4 04-19-2007 12:34 PM
