Deck Slope - Building & Construction - DIY Chatroom Home Improvement Forum
Old 07-25-2013, 03:19 PM   #1
Deck Slope
I am building a small 8' wide x 4' out from the house deck. I sloped the deck away from the house with the intention of it being 1/16" per foot, so a quarter inch. I found a deck building book that recommended this amount and a carpenter I know agreed. I thought my measurements were correct but I had a friend over helping and noticed it was closer to 1/8" per foot (1/2" total). Now that I am doing more and more research online I am finding a lot of information that recommends no slope at all.
Is a half inch slope over 4' way too big?? I feel like I made a mistake but not sure I can go back to correct it or if I even need to. Any thoughts?
john620 is offline   Reply With Quote
Old 07-25-2013, 03:25 PM   #2
kwikfishron's Avatar
Rewards Points: 86
Unless the aesthetics of it is bothering you, you'll be fine. I rarely slope decks.
kwikfishron is offline   Reply With Quote
Old 07-25-2013, 03:51 PM   #3
Right now, just framed, the aesthetics do not bother me too much. I was more concerned about it being a noticeable slope when you are standing on it or put a drink down on it.
When I put up the railings should I make the railing follow the slope or have them level?
Old 07-25-2013, 04:15 PM   #4
Rewards Points: 12,818
I've also never sloped a deck.
Level the railings, that's what the eye will see as being unlevel if you slope them.
Old 07-25-2013, 04:16 PM   #5
Rewards Points: 86
I would notice but most wouldn't. There are instances where decks need to be sloped and when they do 1/8" per foot is the norm.
It sounds like it's bothering you...just shim up the post a bit at the bottom.
Old 07-25-2013, 04:51 PM   #6
Old School
Willie T's Avatar
Since I've never known water to be able to flow across the gaps between boards, I've never sloped a deck. A concrete or tile or brick patio, yes, but not deck.
Willie T
Old 07-25-2013, 04:56 PM   #7
Rewards Points: 86
Concrete, tile, and membrane decks is what I was referring to.
Old 07-25-2013, 10:44 PM   #8
Old School
Willie T's Avatar
You do realize you are talking just a taste over 1/2 a degree, (.6°) in 4 feet?
That would show up as right around 1/32 of an inch across a 3" glass of liquid.
Willie T
Cedar deck help mickbiv Painting 11 08-08-2013 10:21 PM
Fasten deck board from under deck resonator Carpentry 14 09-20-2010 11:15 AM
Deck Staining thread but I am desperate- please help mickbiv Painting 3 09-08-2010 01:28 AM
Building a new deck......suggestions? thoughts? Rhizzlebop Building & Construction 38 06-24-2009 06:07 PM
slope of elevated deck need ideas to make it look right johnny67 Building & Construction 7 06-09-2009 03:59 PM
