Deck Screws Mushrooming... - Building & Construction - DIY Chatroom Home Improvement Forum
Old 09-17-2009, 09:02 PM   #1
Deck screws mushrooming...
I am making progress on my deck, finally installing the deck boards!!
Is there a way to reduce the amount of mushrooming on the composite - choicedek boards?
I put down 5 boards, pre drilled 1/2 and simply screwed 1/2 and all have mushroom effect to them. Any suggestions??? I have "tapped" as the choicedek installation says on the refuse, but you can see it all over the deck.
Also- over time, will the "tapped down" refuse fade away....I bought the screws that match the deck, so I am not worried if they show down the road.
Thanks,
Adam
redroc25 is offline   Reply With Quote
Old 09-18-2009, 05:58 AM   #2
Master General ReEngineer
Bondo's Avatar
Rewards Points: 336
Ayuh,... You could drill a counter-sink when you predrill the holes...
Old 09-18-2009, 09:12 AM   #3
Rewards Points: 1,520
They sell screws that don't mushroom at big box stores.
bob22 is offline   Reply With Quote
Old 09-18-2009, 01:07 PM   #4
screw suggestions
Bob- do you have any suggestions that you have used that don't mushroom then?
Thanks,
Adam
Old 09-18-2009, 01:28 PM   #5
Sorry I don't have a brand name to reference; I know when I did some composite decking at my house I bought them and they worked for me. Try calling one of big box stores and ask them if they have them in store.
Old 09-18-2009, 08:15 PM   #6
Drywall contractor
Rewards Points: 1,070
Yep, HD and Lowes carry screws specifically for the composite decking that are supposed to take care of the issue you're running into.....
If you can read this, thank a teacher. If you can read this in English, thank a soldier. Support our troops.
bjbatlanta is offline   Reply With Quote
Old 09-19-2009, 02:29 AM   #7
morningwood
Everyone above is right.
Please do not 'tap' the mushroom over. You spend tonnes of money on a low maintenance deck and the people at the store say to hammer down the mushroom.
That is the fastest way to ruin the good look of the composite decking.
I install tonnes of the stuff, I iether use the proper screws (small head and extra set of threads)....ask for the proper composite decking screws...they come in colors as well.
If you are stuck, another method is to predrill with a counter sink bit. No mushrooming and the screw sets in and looks real neat. It looks professional, and it is not that much more time consuming, just get a good bit ( around $20-25 bucks will do).
Hope that helps..
rahfiki is offline   Reply With Quote
Tags
composite decking , decks , screen
Composite vs wood deck screws cranedk Building & Construction 6 11-26-2015 04:47 PM
New Trex Deck just installed with wood deck screws instead of composite- HELP PLEASE! JLayman Building & Construction 3 08-07-2009 11:20 PM
Building a new deck....and creative uses of granite scrap in outdoor living space Rhizzlebop Building & Construction 9 05-15-2009 12:17 PM
failing miserably at screwing in 2 inch deck screws gordie howe Carpentry 17 10-28-2008 12:00 PM
DECK decking nails vs screws ... christian15213 Building & Construction 8 05-02-2005 08:51 PM
