Deck Screws - Building & Construction - DIY Chatroom Home Improvement Forum
Old 10-02-2012, 09:08 PM   #1
deck screws
I would like to know how long of a deck screw should I use for my deck boards
basaw1995 is offline   Reply With Quote
Old 10-03-2012, 11:09 AM   #2
Rewards Points: 2,212
What thickness and type of deck Board?
I use 3" screws for 1.25 & 1.5 inch thick boards. Ceramic coated deck screws.
mae-ling is offline   Reply With Quote
Old 10-03-2012, 11:27 AM   #3
I have used 2-1/2" with 1-1/4" decking boards with no problems. The longer the better of course but probably don't need more than 2-1/2".
Make sure you use a coated decking screw. There are epoxy coated, ceramic coated (as mentioned) and probably some others. They are more expensive but if you use something cheap they will rust over time and start breaking.
I would also use something that takes a square or star bit. There will be less stripping that way if you use an impact driver to sink them.
NHtransplant is offline   Reply With Quote
Old 10-03-2012, 11:28 AM   #4
Up here in Canada they are all square drive, Robertson invented it.
Old 10-03-2012, 11:57 AM   #5
For my standard PT decking, I use Deckmate 2.5" screws.
BTW, all Deckmate screws seem to come with starbits these days...
allthumbsdiy is offline   Reply With Quote
Old 10-03-2012, 02:59 PM   #6
journeyman carpenter
woodworkbykirk's Avatar
Rewards Points: 1,248
grk screws are becoming more common, especially for color matched screws for composite decking
if you deck is near the water you'll need to switch to stainless steel Especially if your right next to salt water. reg screws wont last. the salt in the air accelerates corrosion
woodworkbykirk is offline   Reply With Quote
Deck Staining Nightmare steven994 Painting 6 04-06-2014 09:10 PM
TREX decking extremely disappointing KHL General DIY Discussions 266 07-05-2013 11:26 AM
deck screws woodworkbykirk Insulation 0 10-02-2012 09:34 PM
foundation walls to support a deck bubbler Building & Construction 1 04-12-2012 03:27 PM
Ground level deck - screws or bolts? rsmith0399 Building & Construction 9 01-11-2012 12:53 PM
