-   -   deck screws (http://www.diychatroom.com/f19/deck-screws-158825/)
basaw1995 10-02-2012 10:08 PM
deck screws
I would like to know how long of a deck screw should I use for my deck boards
mae-ling 10-03-2012 12:09 PM
What thickness and type of deck Board?
I use 3" screws for 1.25 & 1.5 inch thick boards. Ceramic coated deck screws.
NHtransplant 10-03-2012 12:27 PM
I have used 2-1/2" with 1-1/4" decking boards with no problems. The longer the better of course but probably don't need more than 2-1/2".
Make sure you use a coated decking screw. There are epoxy coated, ceramic coated (as mentioned) and probably some others. They are more expensive but if you use something cheap they will rust over time and start breaking.
I would also use something that takes a square or star bit. There will be less stripping that way if you use an impact driver to sink them.
mae-ling 10-03-2012 12:28 PM
Up here in Canada they are all square drive, Robertson invented it.
allthumbsdiy 10-03-2012 12:57 PM
For my standard PT decking, I use Deckmate 2.5" screws.
BTW, all Deckmate screws seem to come with starbits these days...
woodworkbykirk 10-03-2012 03:59 PM
grk screws are becoming more common, especially for color matched screws for composite decking
if you deck is near the water you'll need to switch to stainless steel Especially if your right next to salt water. reg screws wont last. the salt in the air accelerates corrosion
