Deck Screw In Drywall? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 03-23-2009, 10:18 AM   #1
Deck screw in drywall?
I was in the middle of drywalling my addition last night when I ran out of drywall screws. There wasn't a local hardware store open, so I switched to a 1 5/8" deck screw (phillips, sort of green in color). Used it on about a sheet and a half.
The shape of the screw is nearly identicle, just wondering if anyone knows if I will have a problem down the road? To be honest, they actually drove in a little bit nicer
TIA
Ininkus is offline   Reply With Quote
Old 03-23-2009, 10:26 AM   #2
Tom Struble's Avatar
Rewards Points: 2,002
dont think its a problem but deck screws have a thicker shank it mite reduce its holding power in relitively soft sheet rock, im sure more smarter men than me can help you here tho
Tom Struble is offline   Reply With Quote
Old 03-23-2009, 10:29 AM   #3
Rewards Points: 1,448
I say no problem. Been there done that.
Deck screws are a little fatter than drywall screws so there is a slightly bigger chance of splitting the wood behind if you are using furring strips instead of fastening directly to studs. Also may crumble the drywall more when you are fastening the edge although you may alleviate this by drilling pilot holes. Deck screws are also a little more expensive, at least where I live.
Old 03-23-2009, 10:32 AM   #4
Cool, thanks a lot.
I think you are right on the cost, I'm sure these were more expensive.
Old 03-24-2009, 04:36 PM   #5
Drywall contractor
Rewards Points: 1,070
Screws are screws, as long as they pull the drywall tight to the framing member you should be fine...
If you can read this, thank a teacher. If you can read this in English, thank a soldier. Support our troops.
bjbatlanta is offline   Reply With Quote
Old ceiling replacement idsp General DIY Discussions 12 07-25-2009 11:48 AM
Post detail for raised covered deck jogr Building & Construction 3 05-16-2009 08:46 AM
New deck, nail or just screw it! steve f Building & Construction 3 05-15-2008 09:17 AM
The Bioswale, french drain, deck, drainage dilemma (long) seabright_sc Building & Construction 2 01-05-2008 04:37 PM
Major screw up: Deck stain usaalways General DIY Discussions 4 07-10-2007 03:39 PM
