Deck From Rough Cut Lumber - Building & Construction - DIY Chatroom Home Improvement Forum
Old 01-08-2015, 06:26 PM   #1
Green Hat
Rewards Points: 170
Deck from rough cut lumber
Gents, just trying to ping this off of some of you who may have seen something like this before.
I am building a new barn in my backyard, and am using rough cut lumber. Mainly Poplar and White Oak. I really like the look of the rough cut lumber, especially where I live in the woods.
What would the possibility of using the same type of rough cut lumber for my deck? Mainly the decking and the railings. I would still be using approved and code appropriate lumber for the supporting structure.
Also, what would some of the concerns be for using something like this? Mainly, types of sealant and the ways to keep it preserved over the years.
Thanks!
Andy
Mills314 is offline   Reply With Quote
Old 01-08-2015, 06:46 PM   #2
kwikfishron's Avatar
Rewards Points: 798
If I was sitting on the mother-load of white (not red) oak I'd have no problem using it on a deck. Although there are some strains of Popular that are rot resistant, in general I'd say no way to that.
kwikfishron is online now   Reply With Quote
Old 01-09-2015, 05:43 PM   #3
Rewards Points: 16
We've got a lot of red and yellow cedar around where I grew up. I've made a lot of decks and outdoor structures out of rough cut cedar. It looks nice, it just limits the barefoot opportunities a little.
AKBoater is offline   Reply With Quote
Old 01-09-2015, 05:53 PM   #4
Rewards Points: 986
Originally Posted by kwikfishron View Post
Although there are some strains of Popular that are rot resistant.
What poplar is rot resistant?
Toller is offline   Reply With Quote
Old 01-09-2015, 06:13 PM   #5
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,626
Ayuh,.... None I've ever seen,... Completely Junk,....
White oak has been used alot in ole boat buildin',....
Seems I remember that it's Boiled, to release an enzyme for super rot resistance,...
'round here for rough cut lumber docks, you can find tamarack/ larch, some cedars, hemlock, 'n My favorite, black locust,...
Old 01-09-2015, 06:37 PM   #6
landfillwizard's Avatar
Rewards Points: 516
When i had my farm and vineyard, I always used Black Locust for fence posts or grape posts. Some of the vineyard was on gravel ground and my uncle put in post 40 years before I had to replace some. The black locust had to be dry before it would be rot resistant. However, once seasoned you could even drive a nail with a Hiliti!. I used some black locust for a set of outdoor stairs and had to pre-drill and use tapcons to fasten it together!
landfillwizard is offline   Reply With Quote
Old 01-09-2015, 07:37 PM   #7
Ole Wood Worker
BigJim's Avatar
Rewards Points: 538
I have seen black locust go to growing when used for fence posts, you sure don't want to drive around them, their thorns are so strong and long they will ruin a tractor tire. Black Locust is some really tough wood, it sure won't burn worth a cuss and don't rot easily.
Man that hurts about poplar, that is one of my favorite woods to work with. Down this way there have been many homes with board and batten that have lasted many many years. When yellow poplar is seasoned very well, it is harder than superman's knee caps, at least the old growth was.
I would be concerned from shrinkage when using green lumber, I think it would not look good once all the joints opened up.
New members: Please consider adding your location to your profile.
If you do what you've always done, you'll get what you've always got.
http://www.woodworkingtalk.com/forum.php
Jim
BigJim is online now   Reply With Quote
Cedar deck help mickbiv Painting 11 08-08-2013 09:21 PM
bad lumber for deck issue cbzdel Building & Construction 21 09-30-2012 11:48 AM
Small Deck. Need input on lumber. a2zunknown Building & Construction 15 09-14-2012 08:24 PM
Fasten deck board from under deck resonator Carpentry 14 09-20-2010 10:15 AM
Deck Staining thread but I am desperate- please help mickbiv Painting 3 09-08-2010 12:28 AM
