Deck Roof Support - Building & Construction - DIY Chatroom Home Improvement Forum
Old 03-10-2013, 10:44 AM   #1
Deck roof support
I have a rather standard deck with 4x4 posts every 4' and 2 2x6 beams with metal ties.
I want to screen it in and cover it with a lightweight corrugated plastic roof.
I would rather not tear up the deck to dig holes for the roof posts.
Will it be proper to put post bases centered over the post on top of the beam and put the roof support posts in the bases?
The deck is about 2' above the ground
plschwartz is offline   Reply With Quote
Old 03-10-2013, 12:08 PM   #2
Civil Engineer
Rewards Points: 4,854
The word "proper" is not defined in your post.
If you mean "will it meet code", you are going to have to discuss that with your local building inspector.
If you mean "will it hold up my roof", you need to tell us where you live, so we know what loads your roof is going to hold up. Also post a photo of your deck so the geometry is clear.
Old 03-10-2013, 09:36 PM   #3
DH
Thanks for your response
I guess you did partially answer my question. I didn't want to go to the Building Inspector with an absolute no no and waste his time. (and look stupid).
I live in the town of East Hampton NY. snow load is 20. The deck is 16'along the house and extends 12' Too wet to see if deck is attached to house but I assume so. Parallel to the house 3' distant is a 2 2x 6 beam supported by 4 x4 posts. the outer two posts are 2' from either edge. The 12' between this pair is a center 4 x4 post.
Seven feet o.c. is a second beam supported in a similar manner. The 2' til end of deck.
The 16' 2 2 x 6 beams seem connected to the posts by pairs of ties similar to strongtie AC.
2x6 joists every 16" and covered by cedar decking 16' 5/4 x 6.
The structure will be free-standing per my wife's wishes
I plan to use use polycarbonate panels probably suntuf. The house has a gable roof 4/12 pitch, which I will follow.The house has a 2' eave.
My building plans are simple. A Gable roof supported by the four corner 4x4 posts. I think I put the suntuf roof just over the house roof, so the roof will be ~ 10 1/2 high at the sides.
With 7'oc between the posts and two foot overhang will give the porch full coverage (It will be over the house eave which covers the missing 1 foot). Side overhand also 2'
I overbuilt so 2 2x6 for the beams, 2x6 for the rafters, 2x3 purlins spaced as per need of panel support.
I think the structure will pass the B.I. but I worry about the support for the posts. What is the safest way the bottom of the roof support post to the deck beam centered on the beam support post?
Old 03-10-2013, 10:54 PM   #4
Rewards Points: 13,960
Sure sounds funky to me.
A deck that size should have had 6 X 6's not 4X 4's I can not imagine any inspector approving a roof system built the way your suggesting.
What would stop the side to side movement and wind lift?
Old 03-11-2013, 11:15 AM   #5
well the deck itself was approved by by our BD. Since we get a lot a local McMansions built the BD is known to run a pretty tight ship.
Your opinion on the roof itself is most useful. Thank you.
Both sides of the end of the deck away from the house are quite near mature trees. I am loath to auger 6x6 post holes so near the trees. Which is why I am trying to use the 4x4 posts already in place.
Old 03-11-2013, 11:48 AM   #6
What if we hand-dug out the 4x4 posts and replaced them with adequately supported 6x6 posts?
I would still be left with the post-beam-post situation. Can I separate the pair of 2x6 deck beams and bolt them to the outside of a 6x6 running up to the roof?
Adding deck roof to existing metal roof billybarty Roofing/Siding 2 03-08-2013 06:50 PM
Insulating flat roof deck paredown Insulation 0 05-15-2012 04:33 PM
Roof span and support GD73 Building & Construction 6 07-15-2011 04:48 PM
Support columns for second story roof deck MugsynSax Building & Construction 3 10-05-2010 09:27 AM
A roof for my deck lvgsbrown1 Building & Construction 7 06-30-2009 01:18 PM
