Old 10-21-2009, 12:37 PM   #1
deck roof addition to the existing roof
I extended my front porch roof, I add the new roof on top of the existing roof which is between two gables. I added on top instead of under do to the fact that it was too low. The problem that I am trying to fix is that I am having water leak on the sides of the roof. I add a flash between the sides of the both roofs but the water leak still there, what I can do to seal the leak?
maggiedulzaides is offline   Reply With Quote
Old 10-21-2009, 02:07 PM   #2
Post a few shots.
Ron
Building a new deck....and creative uses of granite scrap in outdoor living space Rhizzlebop Building & Construction 9 05-15-2009 12:17 PM
Tie a shed roof into existing 6/12 roof jj1122_2000 Building & Construction 1 02-18-2009 10:37 PM
The moving Ice Dams after using a roof rake ?? Canufixit Roofing 9 02-05-2009 08:33 PM
new porch roof to existing home jscholl411 Roofing 6 10-12-2007 12:24 AM
Flat roof addition - Joists connected to structure via legerboard?? Rhino17 Building & Construction 2 09-01-2007 07:56 AM
