Deck Restoration - Building & Construction - Page 2 - DIY Chatroom Home Improvement Forum
Old 05-21-2009, 05:28 AM   #16
Rewards Points: 5,336
Originally Posted by Wolfies167 View Post
You both mention toe screwing, but I have no clue how to do that or what it will accomplish. Can someone please explain that in a little more detail assuming I would toe screw the 2x4 from behind the existing support posts? The only reason I hatched the 4x4 plan was because I was worried about splitting the wood from screwing in all of the new panels...
Do a google on toenailing. You should get some pictures.
If you're concerned about splitting the wood, you drill pilot holes to put the screws or nails into. If you're unsure what a pilot hole is, google it.
Ron
Old 05-21-2009, 06:37 AM   #17
Thanks Ron. I did Google it earlier, but I am not sure I will be able to execute that. From what I saw and from what I know of Pilot holes...this is what I get from it. I would be drilling a pilot hole through the 2x4 and the support post. Then, I would use a screw to attach the 2x4 to the support post by drilling it through the pilot hole?
I was at HD at 6am this morning and they did not have hot dipped galvanized screws...or even a bulk quantity of stainless steel.
So, I picked up Deck Mate w/ Evercote? 9x3.5" in size...It has all kinds of lifetime guarantees on the box against rust, etc. Have you ever heard of these?
Wolfies167 is offline   Reply With Quote
Old 05-21-2009, 07:09 AM   #18
Sure, they're another alternative to stainless or galvanized.
Ron
Old 05-22-2009, 03:32 AM   #19
I think I have a good idea of what to do. Now for the new lumber...couple of questions. Pressure treated was mentioned...does it matter what type...Pine, etc.? Also, I have decided to replace almost all of the spindles/balusters and cut new ones...can someone recommend a miter saw that will allow me to make the miter cuts and also just cut regular pieces of lumber?
Old 05-22-2009, 08:07 AM   #20
Pressure treated wood in Southern Yellow Pine.
If you're going to buy a miter saw, don't just buy on for the project you're working on now. Try to think ahead to things you might use it for in the future.
A simple 10" saw might be all you need, but if you plan to cut molding or cross cutting wood 6" or wider, you might want a bevel, sliding saw.
These saws come with either 8", 10" or 12" blades. Prices range from under $100. to $700.
It's doubtful you would need anything over 10" Maybe a simple 8" saw is all you need. For occassional use you could probably go with a Black and Decker or Ryobi saw.
Try looking on Toolseeker.com They have many options where you can pick out quite a few saws to see how they compare in both features and price.
Ron
Old 05-22-2009, 08:32 AM   #21
Thanks again for the info Ron. This is the one I was planning on picking up:
http://www.homedepot.com/webapp/wcs/...ctId=100634340
This will allow me to make straight cuts as well as miter, right?
Old 01-06-2010, 07:03 AM   #22
Thank You to All
Just want to say thank you to everyone who participated in this thread and gave me suggestions and ideas. This was a pretty big project I undertook and was really a first for me in many aspects. Anyway, here is a picture of it finished...I still need to put another coat of paint on the panels, feather in a couple of panel pieces, and some other minor touch-ups, but have to wait for spring. Thanks again!!!
Building a new deck......suggestions? thoughts? Rhizzlebop Building & Construction 38 06-24-2009 05:07 PM
Post detail for raised covered deck jogr Building & Construction 3 05-16-2009 07:46 AM
Building a new deck....and creative uses of granite scrap in outdoor living space Rhizzlebop Building & Construction 9 05-15-2009 11:17 AM
The Bioswale, french drain, deck, drainage dilemma (long) seabright_sc Building & Construction 2 01-05-2008 03:37 PM
