Deck Removal - Building & Construction - DIY Chatroom Home Improvement Forum
Old 12-02-2011, 10:47 AM   #1
deck removal
how do I remove a ground level deck that's attached to my house?
Nick45 is offline   Reply With Quote
Old 12-02-2011, 11:32 AM   #2
kwikfishron's Avatar
Rewards Points: 82
If you’re not trying to salvage anything a chainsaw will make quick work of it.
Cut it up into manageable pieces then unbolt the ledger off the wall.
kwikfishron is offline   Reply With Quote
Old 12-02-2011, 04:57 PM   #3
Rewards Points: 5,336
Are you talking about sequence or tool choice?
Sequence would be:
Railing
Decking
Floor joists
Staircase
Rim joists
Posts
Ledger
Tools:
Sawzall with a wood with embedded nail blades. A few packs.
Ron
B. Franklin 1759
Old 12-02-2011, 04:59 PM   #4
old guy contractor
tcleve4911's Avatar
Rewards Points: 530
With such a vague question, I'd call a contractor .........
tcleve4911 is offline   Reply With Quote
Old 12-02-2011, 05:11 PM   #5
Garrison Construction
Gary Garrison's Avatar
Deck Removal
I would take it apart one piece at a time. Unbolt the ledger last. If material is bad discard into trash as you take apart.
Gary Garrison is offline   Reply With Quote
Old 12-02-2011, 10:57 PM   #6
Residential Designer
AndyGump's Avatar
Rewards Points: 660
Send a message via Skype™ to AndyGump
This could help.
Andy.
AndyGump is offline   Reply With Quote
Deck Staining Nightmare steven994 Painting 6 04-06-2014 10:10 PM
Pergola over existing deck cpfullback Building & Construction 0 08-04-2011 12:36 PM
deck stain removal phatibs01 Painting 7 06-07-2009 09:10 PM
Building a new deck....and creative uses of granite scrap in outdoor living space Rhizzlebop Building & Construction 9 05-15-2009 12:17 PM
