Old 05-10-2006, 08:45 PM   #1
Deck Railings
My deck is nearly complete thanks to some great advice. Now I have to put up my railings from my deck to the ground level. How do I determine the height. From the deck, the height is 38", I have 5 steps to ground level. What height to I cut my 4x4 post that attach to the last step stringer? Thanks again for all the help.
econdave is offline   Reply With Quote
Old 05-13-2006, 05:37 PM   #2
Deck Railings
Where I live the code varies a bit from town to town. One example from a town is gaurdrail shall be at least 36" above surface of the deck. Handrail must be at least 30" but no greater than 34" above the nosing of the treads.
So the question is how are you going to attach the handrail to the gaurdrail, every one I do is a little different from the other.
It might help to lay a board on your steps to show you the angle that the handrail will be at.
It is probably easier for you to install 4x4's level first, then cut your angle on them after you snap a chalk line.
Obviously you need to account for the thickness of the handrail and subtract that thickness from your post height.
Bob
bob the builder is offline   Reply With Quote
Old 05-13-2006, 07:07 PM   #3
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
Deck Railings
As Bob the Builder wrote: Find out what your local code dictates. A question like "what is the residential required height?" can be answered easily by calling your local Building dept. inspection offices.
To determine the height of your stair railing (post height):
The actual measured height is taken from: the nose of your bottom step top (on your stringer), .....measure up........ (Add the height of your railing thickness) = This measurement total = would need to meet your required code.
We always just mark the post top as the required height, and add the railing thickness onto the height so it is slightly above the requirements.
Hope this helps.
Old 05-14-2006, 04:52 PM   #4
Deck Railings
so my ? is, if I cut the top 4x4 post at 38 inches on the top of the stringer, is the bottom 4x4 post cut the same height (38") attached to the nose of the bottom step? thanks.
Old 05-14-2006, 07:40 PM   #5
Deck Railings
econdave,
It sounds like you have it right.....
Old 05-15-2006, 05:56 AM   #6
Deck Railings
thank you, havent been able to work on it, its been raining for a week here...
Old 05-15-2006, 06:30 AM   #7
Deck Railings
Rain, I know....ugh
And more is coming....
Drop the deck project and start building a raft.......
Old 05-16-2006, 06:49 AM   #8
Deck Railings
I hear you. Thanks again for all your help, I just want to get this thing done so I can move on to a new project. I have to build a set of outside stairs to my barn. Heres another ?. Should I use sonatube or just dig the holes and set the post in concrete?
Old 05-16-2006, 07:33 AM   #9
Deck Railings
I definetely recommend using the sonotube. Make sure you get the right diameter that is standard use in the part of the country you're in.
Old 05-16-2006, 05:07 PM   #10
Deck Railings
I am in upstate N.Y. I believe 8" but will check with the building inspector... still raining. Might clear up by Saturday...
Old 07-11-2006, 09:26 AM   #11
Deck Railings
Hello all,
If you are looking for landscape and deck lighting then you need to check out the new SPAM. They are great around hot tubs, to illuminate stairways and docks, or just to add an elegant touch to the perimeter of your deck.
Check them out and get more out of your deck!
If you would like to place an ad, please contact the admin.
Philips is offline   Reply With Quote
deck - beam to post connection (??) brocasArea001 Carpentry 21 05-11-2011 09:39 PM
What size deck is 'good' for our situation? curls00 Carpentry 20 09-08-2007 08:12 PM
deck questions robphelan Carpentry 6 06-25-2006 07:42 PM
Subfloor question for new deck and solarium CM2U Building & Construction 3 07-27-2005 10:50 PM
deck walls maintenance Building & Construction 6 04-03-2005 11:37 PM
