Deck Railing Posts - Building & Construction - DIY Chatroom Home Improvement Forum
Old 05-29-2008, 12:03 PM   #1
Rewards Points: 152
Deck railing posts
Hello All,
What is the best way to attach railing posts in this way:
I do not see any lag bolts. Is this a sturdy method? I like the look of it.
sandyman720 is offline   Reply With Quote
Old 05-29-2008, 12:18 PM   #2
Why can I see Through the corner?
UFoPilot is offline   Reply With Quote
Old 05-29-2008, 12:33 PM   #3
Rewards Points: 152
I dont understand what you are talking about. "Why can I see Through the corner?"
Old 05-29-2008, 01:14 PM   #4
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
That's a UPC Tag stapled to the end of the rim joist board.
- Build Well -
Old 05-29-2008, 01:15 PM   #5
Rewards Points: 152
Atlantic, any ideas of the attachment method of the railing posts?
I like the clean look of it rather than lagging to rim from outside.
Old 05-29-2008, 01:16 PM   #6
Originally Posted by sandyman720 View Post
Hello All,
It's probably a doubled rim joist and is lagged screwed from the inside,and maybe even "blocked-in".
Example: Using ledgelock Lag screws.
- Build Well -
Old 05-29-2008, 01:49 PM   #7
Rewards Points: 152
Are lag screws or bolts better to use in this case?
Old 05-29-2008, 02:53 PM   #8
There's a chance that the railing posts that are shown in your pick could be:
1.) Neither lagged-screwed, nor carriage-bolted, but only Blocked-in with PT lumber.
2.) They are lagged in, or carriage bolted in, and they placed the second rim joist "over" the heads of the lag/bolt, to hide them.
IMHO - I believe that both lag-scews and carriage bolts can work, if inserted effectively.
We used to use carriage bolts, but now pretty much just use ledgerloks. They may, or may not be approved in your region (check your local code requirements for deck post fastening)
These pics might help you:
Ledger Lock Lag screws:
We prefer to also "block-in" the posts, along with the ledgerloks:
Post cracked on the very end a little here, but it isn't going anywhere, and it passed inspection:
- Build Well -
Extending height of deck railing tntworks General DIY Discussions 4 03-11-2013 07:16 AM
Deck Posts JackOfAllTrades Building & Construction 18 02-05-2008 01:36 PM
Support posts for 12' high deck hotchkiss Remodeling 3 09-05-2007 06:32 PM
Deck Posts question flyultralite Building & Construction 1 06-23-2007 09:18 AM
UGH! just realized one of my deck posts is cut too short nasdaqer Carpentry 8 06-19-2007 07:26 AM
