Deck Railing Post Installation - Building & Construction - DIY Chatroom Home Improvement Forum
Old 06-19-2012, 11:02 AM   #1
Deck railing post installation
I plan on installing a vinyl rail system. What is the best way to attach 4x4 post (outside of frame) mounted on top of the decking (notched) to support a vinyl post sleeve over the post so that the bottom of the sleeve is fully supported?
beau04005 is offline   Reply With Quote
Old 06-19-2012, 03:12 PM   #2
kwikfishron's Avatar
Rewards Points: 602
Pages 15 and 16.
http://www.awc.org/publications/DCA/DCA6/DCA6-09.pdf
kwikfishron is online now   Reply With Quote
Old 06-20-2012, 10:54 AM   #3
Railing post
The info yousent helped. Specifically, I am looking for help on framing to support my 4x4 post being notched to be installed on the installed decking and being bolted to the framing. When I do this, it will create a situation where there will be an opening on the vinyl sleeve that I will be installing over the post to support vinyl railings. The bottom of the sleeve on the outside will not be resting on anything. I am looking for help to fill this gap in so that the sleeve bottom is supported. Basically, I am trying to sandwich the post where it attached to the framing.
foundation walls to support a deck bubbler Building & Construction 1 04-12-2012 03:27 PM
Deck Railing Earnie Building & Construction 6 09-06-2011 10:28 AM
Mahogany Deck Installation - Before & After Pictures AtlanticWBConst. Project Showcase 23 01-06-2011 09:56 PM
Is it SAFE not to use deck post concrete anchors? z_zk_z Building & Construction 3 06-28-2010 09:35 PM
deck railing suggestion redroc25 Building & Construction 3 09-14-2009 11:13 AM
