Deck Railing - Building & Construction - DIY Chatroom Home Improvement Forum
Old 09-03-2011, 09:35 AM   #1
Rewards Points: 280
Deck Railing
How structural is Azek or Fiberon deck railing?
My deck will be 10' x 10'. If I use the 6' rail sections, I will need center posts at about 4'6" from the end posts.
Can I instead use the 12' sections unsuppored in the center for a 9' + run of railing? If so, I would not need the three center posts and post sleeves at a considerable cost savings.
Would you feel safe with that rail length on a deck 10' above ground?
Earnie is offline   Reply With Quote
Old 09-05-2011, 08:29 AM   #2
Rewards Points: 280
No one has used Azek or Fiberon railing?
Old 09-05-2011, 11:01 AM   #3
I have installed azek several times. It's a great railing and very sturdy. Timbertech also makes a great railing with lighting kits that are great. I usually don't span more than 8 ft for aesthetic purposes.
dvatt is offline   Reply With Quote
Old 09-05-2011, 12:42 PM   #4
Rewards Points: 280
After more searching and reading, the NC Residential Code specifies that railing posts cannot exceed 78" on center. So I'm back to using the 6' railing sections and cutting off the excess.
Old 09-05-2011, 02:25 PM   #5
That's absurd you can only go that far
Old 09-05-2011, 03:37 PM   #6
Rewards Points: 107
Deck Railing
I just completed a Timber Tech Radiance Railing Project which you can see in the project showcase section. It comes in 6 feet and 8 feet lengths. The kits come with crush blocks. There is one in the6 foot kit and 2 in the 8 foot kit so you can space them properly. This has proven to be a very sturdy system
Ranger1227 is offline   Reply With Quote
Old 09-06-2011, 11:28 AM   #7
Rewards Points: 280
I agree. Too restrictive.
While applying for my permit an inspector told me years ago an NC Congressman's son was hurt when an elevated deck fell. Not sure if this actually happened or if it was the reason for the restrictive deck code.
Deck Staining Nightmare steven994 Painting 6 04-06-2014 10:10 PM
Extending height of deck railing tntworks General DIY Discussions 4 03-11-2013 08:16 AM
Pergola over existing deck cpfullback Building & Construction 0 08-04-2011 12:36 PM
Building a new deck....and creative uses of granite scrap in outdoor living space Rhizzlebop Building & Construction 9 05-15-2009 12:17 PM
