Deck Questions - Building & Construction - DIY Chatroom Home Improvement Forum
Old 05-07-2007, 02:04 PM   #1
Rewards Points: 790
Deck Questions
1. Has anyone seen or done a deck railing using horizontal steel pipes? I have noticed some in my area and would like that on my new deck once it is built.
cibula11 is offline   Reply With Quote
Old 05-07-2007, 02:53 PM   #2
concretemasonry's Avatar
Rewards Points: 2,654
It is possible that you might run into either code or safety issues. Horizontal pipes are great in an industrial situation, but a home is different.
When you go to sell your home, a home inspector may point out the safety issue because children can fit through and fall or choke. - The codes require no more than a 4" wide gap on decks and stairways, for example. Home inspections do not always relate directly to codes, but do address safety issues even if they comply with code approvals.
I still have not figured out how the strung cables pass some of the codes even if they are strong enough.
concretemasonry is online now   Reply With Quote
Old 05-07-2007, 02:53 PM   #3
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
Cibula,
I think that what you are seeing are the cable railing sytems.
Link:
http://www.cablerail.com/standard/installation.shtml
- Build Well -
Old 05-07-2007, 03:23 PM   #4
Rewards Points: 790
Here is a picture of what I am referring to. I know the whole "climbing" thing could be an issue. But if they were spaced at no more than 4" apart, I guess I don't see why they would not pass code. I have seen SEVERAL houses in newer developments with these railings.
Old 05-07-2007, 03:33 PM   #5
Handyguy
Brik's Avatar
Send a message via Skype™ to Brik
I have done the vertical ones a couple of times. Dekorators or some such brand. They look nice and aren't as climbable. Sort of expensive IIRC. I was also thinking copper pipe, lettering cleaned off and treated to accelerate the verigation process may look nice some day.
Brik is offline   Reply With Quote
Old 05-07-2007, 03:34 PM   #6
robertcdf's Avatar
Its called Piperail and Deckorators makes it. http://www.deckorators.com You would want to check as some codes may not allow it even if the spaces are less than 4" because kids can climb it like a ladder and may fall over the edge.
robertcdf is offline   Reply With Quote
Old 05-08-2007, 06:54 AM   #7
Rewards Points: 324
I used cedar with vertical aluminum posts. Very cost effective I think. Drilled the holes and pushed in the posts. It only took a day to drill and install. I installed the posts 4.5" OC and the posts are 3/4" diameter to technically the the gaps are 3 3/4" apart I believe.
tigerbalm2424 is offline   Reply With Quote
Old 05-08-2007, 11:09 AM   #8
Rewards Points: 790
What did you use for the pipes?
Old 05-08-2007, 12:04 PM   #9
Rewards Points: 324
If you were asking me, I used 3/4" aluminum posts that were factory painted black. I found them an menards for $1.04/piece. I also found them at HD and Lowes but they were more expensive.
Old 05-08-2007, 12:07 PM   #10
Rewards Points: 790
Did they come that length or did you have to cut each one to size?
Old 05-08-2007, 12:17 PM   #11
Rewards Points: 324
They came cut to 30" size.
Go to home depot and search "Dek Rail" and you will see them.
Here they are as HD but a lot more expensive. They are sold in all different lengths.
deck - beam to post connection (??) brocasArea001 Carpentry 21 05-11-2011 08:39 PM
What size deck is 'good' for our situation? curls00 Carpentry 20 09-08-2007 07:12 PM
Deck questions DLP600 Building & Construction 12 04-29-2007 11:22 AM
deck questions apowens Carpentry 6 04-10-2007 07:35 PM
deck questions robphelan Carpentry 6 06-25-2006 06:42 PM
