Deck Questions - Building & Construction - DIY Chatroom Home Improvement Forum
Old 08-05-2010, 09:50 PM   #1
Rewards Points: 152
Deck Questions
Here's my deck
Couple questions:
1) We can feel a bit of sway on the top deck when the kids are running around. Can I add some bracing/gussets to the posts to stiffen it up a bit?
2) The lower deck has posts on deck blocks that have been buried in the dirt and are rotting pretty badly. You might also notice the lack of railings. Would I be able to tie into the upper deck posts (front/rear plates, joist hangers...?) instead? Would this also serve to stiffen up the top deck?
Thanks in advance for any opinions,
Shawn
burnt03 is online now   Reply With Quote
Old 08-05-2010, 10:13 PM   #2
jlhaslip's Avatar
Rewards Points: 1,116
Indeed, knee braces at the posts will help, but also, diagonal bracing between joists will also assist in removing the swaying you feel now.
Start the diagonal bracing at the house and run it on a 45 degree angle towards the outer rim joist. One line in each direction would be best.
Originally Posted by Bud Cline View Post
Go ahead and apply for a variance, those guys at City Hall can use a good laugh.
jlhaslip is online now   Reply With Quote
Old 08-08-2010, 01:11 AM   #3
Rewards Points: 152
Thanks jlhaslip,
Are you talking a single board on the bottom surface of the joists running diagonally?
Anyone else with any thoughts on whether I can tie the bottom deck into the posts for the top deck? If it's ok, would I be better off sistering an extended joist on or running new?
Deck Staining Nightmare steven994 Painting 6 04-06-2014 10:10 PM
Floating deck questions DIYguy2000 Building & Construction 6 04-23-2010 11:59 AM
Leaking deck flashing questions....help! Oxymoron Building & Construction 6 01-03-2010 10:54 PM
Building a new deck....and creative uses of granite scrap in outdoor living space Rhizzlebop Building & Construction 9 05-15-2009 12:17 PM
