-   -   Deck Questions (http://www.diychatroom.com/f19/deck-questions-78036/)
burnt03 08-05-2010 08:50 PM
Deck Questions
Here's my deck
http://carphotos.cardomain.com/ride_...4003_large.jpg
http://carphotos.cardomain.com/ride_...4002_large.jpg
http://carphotos.cardomain.com/ride_...4001_large.jpg
Couple questions:
1) We can feel a bit of sway on the top deck when the kids are running around. Can I add some bracing/gussets to the posts to stiffen it up a bit?
2) The lower deck has posts on deck blocks that have been buried in the dirt and are rotting pretty badly. You might also notice the lack of railings. Would I be able to tie into the upper deck posts (front/rear plates, joist hangers...?) instead? Would this also serve to stiffen up the top deck?
Thanks in advance for any opinions,
Shawn
jlhaslip 08-05-2010 09:13 PM
Indeed, knee braces at the posts will help, but also, diagonal bracing between joists will also assist in removing the swaying you feel now.
Start the diagonal bracing at the house and run it on a 45 degree angle towards the outer rim joist. One line in each direction would be best.
burnt03 08-08-2010 12:11 AM
Thanks jlhaslip,
Are you talking a single board on the bottom surface of the joists running diagonally?
Anyone else with any thoughts on whether I can tie the bottom deck into the posts for the top deck? If it's ok, would I be better off sistering an extended joist on or running new?
