Deck Question - Building & Construction - DIY Chatroom Home Improvement Forum
Old 06-03-2013, 01:08 PM   #1
deck question
Hi,
I have a quick question about those deck piers you can purchase at HD or lowes. Since the space in the pier only allows one 2x. Can I position the pier under the next joist so I can double up the rim joist. Basically cantelievering it to create a beam or do the rim joists need to be support directly by the deck piers.
markharmon is offline   Reply With Quote
Old 06-03-2013, 01:12 PM   #2
Rewards Points: 13,458
I can not think of a single use for those piers unless you were building some temperary platform.
Most places they would never meet code.
Old 06-03-2013, 01:13 PM   #3
Old School
Willie T's Avatar
Wow. I never even thought about it. That is one heck of a good question.
If doubled-up beams are to often sit on them, why don't the sell them in 3" notch sizes, too?
I guess you could use them in Canada and Kentucky.
Willie T
Old 06-03-2013, 01:27 PM   #4
So, I can't do what I asked?
Old 06-03-2013, 01:32 PM   #5
Old School
Willie T's Avatar
Actually, you need "tie-down" provisions, as well as simply a "support" function, and these little notched blocks give none of that.
Willie T
Old 06-03-2013, 01:42 PM   #6
Old School
Willie T's Avatar
These would be OK for in-between support, but the beams would still have to be firmly anchored down at least at the ends.
Willie T
Old 06-03-2013, 05:36 PM   #7
For a 6' foot fence how much of the post should be above ground or is it more preference?
Old 06-03-2013, 05:49 PM   #8
kwikfishron's Avatar
Rewards Points: 410
6'.
How did your question go from a deck to a fence?
kwikfishron is offline   Reply With Quote
The Following User Says Thank You to kwikfishron For This Useful Post:
Willie T (06-03-2013)
Old 06-03-2013, 06:06 PM   #9
Originally Posted by kwikfishron View Post
6'.
Just curious about the fence.
Old 06-03-2013, 10:31 PM   #10
Dave Sal's Avatar
Rewards Points: 634
For a six foot fence, you want six foot above ground, with three feet below grade to get below the frost line, assuming you are in a location where the ground freezes. Also, some localities limit the height of a fence to six feet.
Dave Sal is offline   Reply With Quote
Deck Framing Question ModernDayDarwin Building & Construction 7 05-18-2013 08:28 PM
Deck Railing Question RodBarney Building & Construction 17 04-20-2013 10:52 PM
Attached deck question. Bugman1400 Building & Construction 31 09-09-2012 11:11 AM
16 x 20 deck question canyonbc Carpentry 9 01-12-2010 08:01 PM
Building a deck - another project for later this summer (Question re: materials) DyerWolf Carpentry 8 05-07-2009 01:41 PM
