Deck Question - Building & Construction - DIY Chatroom Home Improvement Forum
Old 03-22-2013, 11:26 AM   #1
Deck Question
I currently have a 24x18 deck and some of the decking boards are getting bad. The reason is because who ever built it before I moved in used 2x10 for the joists which is a good thing but the when the decking boards were nailed on top of the 2x10 end to end that part is starting to come apart and rot because they have 4 nails all in a small area. My question is what could I use for a joist in the areas that I need to connect the decking area end to end. Hope this makes sense.
speedracer2013 is offline   Reply With Quote
Old 03-22-2013, 11:30 AM   #2
Rewards Points: 14,010
Make since? Sort of.
Got a picture to make sure?
Just nail a 2 X 4 to the side of the joist if the fasners need to be moved back some.
Use ceramic coated deck screws not nails when attaching the new deck boards.
hand drive (03-24-2013)
Old 03-22-2013, 03:04 PM   #3
GBrackins's Avatar
Rewards Points: 2,108
maybe .....
a photo would certainly clear things up and get you useful answers
Welcome to the Forum!
Gary
"You get what you pay for, and sometimes free costs more!"
GBrackins is offline   Reply With Quote
Old 03-23-2013, 11:11 AM   #4
greetings from Bolivia
harrymontana's Avatar
Send a message via Skype™ to harrymontana
use always stainless steel screws, in some woods non stainless steel screws or nails provoke stains, then the ends of the deck boards need to be sealed, this is to close the pores of the wood grain, and we (we are a hardwood exporter) we seal with parafine, something like candle wax, but in your hardware store there must be some kind of sealer.
harrymontana is offline   Reply With Quote
Old 03-24-2013, 10:24 AM   #5
Rewards Points: 272
only problem with your theory is Stainless steel screws are :
1) too damn costly
2) Much weaker than good quality decking screws that tear into the wood.
fixrite is offline   Reply With Quote
Old 03-24-2013, 11:34 AM   #6
AHH, SPANS!!!
Rewards Points: 1,166
Joe's post makes the most sense. scab a 2x to the sides of the joists to extend the available flat nailing surface and re screw the deck boards to the scabbed 2x. if the ends of the deck board are really bad cut back one or two joists from the bad deck board seam and replace with new deck boards.
hand drive is offline   Reply With Quote
Old 03-24-2013, 11:39 AM   #7
I use ceramic coated decking screws.
Far less cam out and 1/2 the price of stainless.
Old 03-24-2013, 12:27 PM   #8
Rewards Points: 272
good choice Joecaption
Old 03-24-2013, 01:02 PM   #9
Roofmaster
Rewards Points: 2,210
What Joe said, and through drill and countersink the deck boards, pilot drill the nailer, and use good square drive stainless steel screws. Assuming ACQ, that stuff is hell on ferrous fasteners, and Aluminum.
Decks collapsing from the use of ACQ soon coming to a theater near you. Not IF....... When.
Old 03-25-2013, 12:25 AM   #10
Rewards Points: 272
I use the Kreg decking system which puts the screws ( for pressure treated wood) in on the side of the planks. No need to countersink or pilot holes. Great system.
Old 03-25-2013, 08:45 AM   #11
like the camo system
Old 03-25-2013, 08:58 AM   #12
Kerg is a great tool system but has no use when installing top side deck screws.
Old 03-25-2013, 10:50 AM   #13
Rewards Points: 272
thats the whole point Joe, WHY install your screws from the top, when you can make it sooo much better by installing from the sides. Far superior for durability, strength, not to mention the looks.
Old 03-25-2013, 11:42 AM   #14
His issue is with the ends of the boards, not in the middle.
Sure way to split it out screwing from the sides on the ends.
Deck Staining Nightmare steven994 Painting 6 04-06-2014 09:10 PM
Attached deck question. Bugman1400 Building & Construction 31 09-09-2012 11:11 AM
16 x 20 deck question canyonbc Carpentry 9 01-12-2010 08:01 PM
Building a new deck....and creative uses of granite scrap in outdoor living space Rhizzlebop Building & Construction 9 05-15-2009 11:17 AM
Building a deck - another project for later this summer (Question re: materials) DyerWolf Carpentry 8 05-07-2009 01:41 PM
