Old 10-23-2010, 09:30 PM   #1
Deck posts in AZ - pressure treated?
I live in Tucson, AZ and am building a deck. It will be supported by 4x4's buried in the ground. I plan on using pine 4x4's and seal them before burying them. Is this sufficient to prevent rotting, or should I be using pressure treated 4x4's? Thanks!
danritz is offline   Reply With Quote
Old 10-24-2010, 07:19 AM   #2
Super Moderator
I would use pressure treated---not for the rot resistance but for insect resistance.
Do check your local code for required methods---In many areas deck posts must sit on top of a concrete pier---It would be bad to have to rip out your work if a code enforcer found a violation.
Mike--
danritz (10-24-2010)
Old 10-25-2010, 01:01 AM   #3
Moderator
As Mike said, check locally. You may be under the 2006 Deck Code (no 4x4): http://www.lancova.com/deckinfo.pdf
Gary
Clothes taking longer to dry?
Shoddy Pressure Treated Lumber? spanky77 Building & Construction 17 06-25-2011 09:09 AM
How do I secure deck railings between posts tigereye Building & Construction 19 05-10-2009 05:49 PM
warped deck rail posts cakem Carpentry 1 05-09-2009 09:24 AM
Q:Temp support to replace beam and posts on deck dougq Building & Construction 10 09-02-2008 05:24 PM
Pressure treated wood - attracts bees? mcvane Carpentry 4 08-31-2007 09:43 AM
