Deck Posts - Building & Construction - Page 2 - DIY Chatroom Home Improvement Forum
Old 05-30-2012, 08:12 AM   #16
dpach's Avatar
Originally Posted by cortell View Post
Very smart, dpach. You installed a membrane to prevent water penetration between members of the built-up beam.
I also put Blueskin on every joist as well since most joist rot occurs when water runs off the floor and under the deck boards and soaks into the joist around the screw holes that hold the deck boards on. The membrane is rubber with a tar layer underneath to seal around the screws. Also used the Bakor glue first as extra adhesive.
It cost a whooping $250 to do a 20 x 14.5 foot deck......peanuts really.
dpach is offline   Reply With Quote
Old 05-30-2012, 12:12 PM   #17
Rewards Points: 150
Ate those deck screws used to build beam and for the Simpson hardware???
MikeVila is offline   Reply With Quote
Can Deck Posts be fixed to existing rock? drcieslak Building & Construction 3 08-03-2011 04:35 PM
how to install deck rail posts? tpcolson Building & Construction 1 11-14-2010 05:19 PM
Fastening deck posts to concrete spaceman spif Carpentry 6 10-11-2010 06:09 PM
How do I secure deck railings between posts tigereye Building & Construction 19 05-10-2009 04:49 PM
help - pressure treated 4x4 deck posts splitting frank090870 Carpentry 17 05-03-2009 06:19 PM
