Deck Posts - Building & Construction - DIY Chatroom Home Improvement Forum
Old 02-23-2012, 11:42 AM   #1
deck posts
i need to replace my current deck that is approx 7 feet about a poured concrete patio. The current deck ledger board is anchored through the house foundation and the deck posts sit on top of the patio anchored with L-brackets. When I replace the deck can I put the posts right on top of the patio or do I need to drill holes in the patio and pour footings.
cwecke is offline   Reply With Quote
Old 02-23-2012, 12:35 PM   #2
Civil Engineer
Rewards Points: 4,514
If you are planning to get a permit, you need to discuss the foundation question with the building inspector. They may allow you to place directly on the slab, they may require testing of the slab to determine if there are footings under the posts, or they may require a new footing under each post.
If you are not planning to get a permit, then the question is what is your basis of design? If you are planning to follow International Residential Code then you need a footing under each post. The required size and depth of footing is discussed extensively in the Prescriptive Residential Wood Deck Construction Guide, available over the internet or perhaps from your building inspector. Footing size and depth is a function of the frost depth, beam and joist span, and soil type.
Old 02-23-2012, 01:55 PM   #3
robertcdf's Avatar
Daniel is giving you good advise, it is also helpful to post your location so we can better help you.
robertcdf is offline   Reply With Quote
Can Deck Posts be fixed to existing rock? drcieslak Building & Construction 3 08-03-2011 05:35 PM
how to install deck rail posts? tpcolson Building & Construction 1 11-14-2010 06:19 PM
Fastening deck posts to concrete spaceman spif Carpentry 6 10-11-2010 07:09 PM
How do I secure deck railings between posts tigereye Building & Construction 19 05-10-2009 05:49 PM
help - pressure treated 4x4 deck posts splitting frank090870 Carpentry 17 05-03-2009 07:19 PM
