Deck Posts. - Building & Construction - DIY Chatroom Home Improvement Forum
Old 06-03-2011, 05:56 AM   #1
deck posts.
GGot holes dug 3ft deep and now 3 quarters filled with water. Was going to pour bag in dry then top it off with soil but now not sure what I should do ground really wet and fills back up we've had a lot of rain here in northwestern pa
dprhino81 is offline   Reply With Quote
Old 06-03-2011, 06:49 AM   #2
Rewards Points: 1,216
Are you installing concrete foundation colums with the deck support sitting on top or are you direct burial of the deck supports?
COLDIRON is offline   Reply With Quote
Old 06-03-2011, 07:26 AM   #3
I would not do it that way. Pump the holes as dry as you can, then mix the concrete normally, mixing it on the dry side. Too wet concrete loses strength. As suggested, using sonotubes is a good idea.
Old 06-03-2011, 08:37 PM   #4
Stairguy
Millertyme's Avatar
Rewards Points: 508
Also keep in mind that wood should not be set directly into the concrete. You should set an anchor into the concrete and then fasten your post. Some inspectors may actually fail you if post are in the concrete. The wood will shrink inside the concrete and create a space between the concrete and the post causing a pocket for the water to sit in and not drain. This will cause premature rot.
Millertyme is offline   Reply With Quote
Old 06-05-2011, 07:51 PM   #5
Send a message via ICQ to getzjd Send a message via AIM to getzjd Send a message via MSN to getzjd Send a message via Yahoo to getzjd
I agree. Drain the holes and mix the concrete as directed for the proper strength.
getzjd is offline   Reply With Quote
Double Level Deck 6x6 posts Skytree Building & Construction 3 09-07-2009 11:47 AM
Guidance needed for deck support posts Mike Loyd Building & Construction 4 08-23-2009 08:03 PM
Deck Posts replacement with load bearing columns from Pacific Columns, Inc Bruce Wilson Building & Construction 7 05-24-2009 03:55 PM
Building a new deck....and creative uses of granite scrap in outdoor living space Rhizzlebop Building & Construction 9 05-15-2009 12:17 PM
Q:Temp support to replace beam and posts on deck dougq Building & Construction 10 09-02-2008 05:24 PM
