Deck Post Supports - Building & Construction - DIY Chatroom Home Improvement Forum
Old 04-04-2014, 11:07 AM   #1
Deck Post supports
I am planning on building a 17x23 deck and have checked the code in my area I plan on using 6x6 cedar posts and I am required to install them on a cement footing I was wondering if you could recommend a good post anchor I was thinking of using Simpson ABA66Z but not sure what other options I have. Thanks
hogboy is offline   Reply With Quote
Old 04-07-2014, 04:12 PM   #2
GBrackins's Avatar
Rewards Points: 2,104
make sure to find out what the actual dimension of your columns will be, i.e., 5-1/2"x5-1/2" or are they 6"x6". Simpson makes rough sawn column bases that are for a true 6x6.
I myself use the ABU66Z many times due to uplift loads on the structure.
Could always check with your local building department and see if they have a requirement for decks.
Good luck!
Gary
"You get what you pay for, and sometimes free costs more!"
GBrackins is offline   Reply With Quote
Replaceing 6" x 6" post on a settleing pool deck. Queequeg152 Building & Construction 7 08-21-2012 10:29 AM
Deck Post Lighting obxbnd Building & Construction 7 08-09-2012 08:44 AM
Post detail for raised covered deck jogr Building & Construction 3 05-16-2009 07:46 AM
Two-Level Deck Post Question Melanie337 Carpentry 2 09-23-2007 11:34 PM
