Deck Post Lighting - Building & Construction - DIY Chatroom Home Improvement Forum
Old 08-08-2012, 12:05 PM   #1
Deck Post Lighting
Hope someone can help me with this. I want to add deck post light caps to an existing deck. The deck posts are 4 x 4 with a vinyl sleeve. There is not enough space to run a wire between the sleeve and the post. The post is about 36" high. Rather than taking down the rails, removing the sleeves and notching out 20 posts, is there a way I can drill a hole in the center of each post to accommodate the wire. If so, what tools would I need. Otherwise, it may be easier to use solar lighting although the lighting effect is not as nice. Thanks for your suggestions.
obxbnd is offline   Reply With Quote
Old 08-08-2012, 02:54 PM   #2
Rewards Points: 79
Don't they make thin wire that's meant to tape to the wall and be painted over? I've seen it in some ads, but don't know anything about it. You might be able to slip that between the post and sleeve, however I doubt its meant for outdoors.
Dwillems is offline   Reply With Quote
The Following User Says Thank You to Dwillems For This Useful Post:
obxbnd (08-09-2012)
Old 08-08-2012, 07:14 PM   #3
robertcdf's Avatar
It's NOT fun however it is doable. Start with a 3/4" paddle bit with 12" extensions, once you get about 18-24" in switch to a 1/2" paddle bit to finish it off. Oh yeah I forgot to mention you need to drill from below so the sawdust falls out of the post as you do it, you can try from above with a shop-vac but it doesn't work as well.
robertcdf is offline   Reply With Quote
The Following User Says Thank You to robertcdf For This Useful Post:
obxbnd (08-09-2012)
Old 08-08-2012, 07:59 PM   #4
"So I Re-Wired It"
MisterZ's Avatar
outdoor wiring needs to be protected. not having seen your deck railings, i would suggest running thru conduit.
then you could hide the conduit by running 2x4 between posts. also this would add means in which to fasten the conduit.
you should post this in the electrical section for advice about outdoor wiring
Knowledge is Power, but 240v can Keel You!!
MisterZ is offline   Reply With Quote
The Following User Says Thank You to MisterZ For This Useful Post:
obxbnd (08-09-2012)
Old 08-08-2012, 08:03 PM   #5
Rewards Points: 12,876
I'd stick with the solor, two screws and your done.
Wiring, transformers, running power to the transformer, and wait until you see the pricing of the low voltage lights.
obxbnd (08-09-2012)
Old 08-09-2012, 12:20 AM   #6
Rewards Points: 79
You could just settle for a different type of lighting. Like those pucks that are recessed into the deck and shine up.
obxbnd (08-09-2012)
Old 08-09-2012, 12:51 AM   #7
Like this?
http://www.rockler.com/product.cfm?p...1&site=ROCKLER
They also work in the risers where you really need them.
obxbnd (08-09-2012)
Old 08-09-2012, 09:44 AM   #8
Rewards Points: 79
Originally Posted by joecaption
Like this?
Yeah, those are what I was taking about. Or I just thought of this... Those raceways that go directly on the wall. It'll hide the chord, white should blend in or can be painted, and it'll look like trim if placed right.
http://homedepot.digby.com/homedepot...ged+Cord+Cover
obxbnd (08-09-2012)
Deck Post repair HobbyMan Building & Construction 5 07-14-2012 03:06 AM
Another Deck Question...Gable Roof Post Placement Issues. mgh-pa Building & Construction 2 06-02-2011 07:26 AM
Deck Post Cracks judexromo Building & Construction 2 06-03-2010 07:41 AM
Outdoor Lighting For Deck cwalker6 Electrical 3 05-20-2009 07:39 PM
Two-Level Deck Post Question Melanie337 Carpentry 2 09-24-2007 12:34 AM
