-   -   Deck Post Height for Composite Post Railing (http://www.diychatroom.com/f19/deck-post-height-composite-post-railing-40807/)
ylwdog 03-21-2009 01:50 PM
I am installing a composite/vinyl railing on a second story deck and would like advice for the post height.
The railing is 36" tall w/ a 39.5" high post, (from the decking), 4x4 post and I have 48" composite post sleeves. What height would you recommend for the post sleeve for the final post height? I am thinking 42" for a nice aesthetic look. This would give me 6" between the top rail and the top of the post. Any other opinions and why?
Thanks,
Doug
jaros bros. 03-21-2009 04:41 PM
42" will be fine.
Bob Mariani 03-21-2009 05:07 PM
cut the sleeve to 38" it sits on the deck and the post skirt sits on the decking around it. The railing is set at 36" high leaving a small reveal (2") before the post sleeve cap.
DecksEtc 03-22-2009 08:07 PM
You say it's a second story deck so I will assume it's at least 8' off the ground.
Where I live the code height for railings on a deck that high is 42" - height from the top of the deck to the top of the railing top rail.
Bob Mariani 03-22-2009 08:15 PM
In CT it is only 36" and there you have nothing to fall into but snow.
carpenter man 11-15-2010 10:01 AM
2nd story deck height
I live in South Jersey . I have done a lot of vinyl railings and fiberglass decks here along the shore. The code here for a second story deck is also 42" I always cut my sleeves at 44 " . Consider the post cap may add around one inch or slightly less.
BTW . Fiberglass decks are very durable, watertight and require little maintenence . The gel coat which is the final top layer can be tinted to just about any color to match your siding colors. Re apply gel coat about every 10 years . Apply with standard paint roller .garydoran29@yahoo.com if you need any fiberglassing tips.
