Deck Planning Advice. - Building & Construction - DIY Chatroom Home Improvement Forum
Old 05-03-2013, 12:19 PM   #1
Deck planning advice.
What I would like is some advice on planning out the deck.
The size of the deck will be roughly 16' x 8' (from the door to the driveway). I would like to have it be a covered deck. I would also like to not attach the deck to the house.
My biggest concern will be the roof height as I would love to try and keep it under the rain gutters that are there now. Unless someone has any better suggestions.
There is about 2 feet from the top of the door to the bottom of the gutters would that be enough for rafters and a roof or am I going to have to extend the rafters/roof above the gutters?
Thinking http://www.houzz.com/photos/156678/H...scape-new-york but next to the house.
Thanks,
dabeast is offline   Reply With Quote
Old 05-03-2013, 12:41 PM   #2
MJ Force's Avatar
Rewards Points: 150
I think your biggest concern at this point is whether your municipality or district will allow this. Visit with them first to see what is allowed and what permits are required. You don't want a stop work order placed on your project or have to tear down all your good work. You neighbors may get a little excited if they see any additions going on. Due diligence.
MJ Force is offline   Reply With Quote
Old 05-03-2013, 02:30 PM   #3
Yes i'll get all permits needed. They don't place a ton of restrictions on decks/porches. I am more looking for advice on what would be best way to do it.
Old 05-03-2013, 02:52 PM   #4
Old School
Willie T's Avatar
You sure that's 2 feet? It looks more like maybe 10" to maybe 14".
Willie T
Old 05-03-2013, 03:31 PM   #5
GBrackins's Avatar
Rewards Points: 2,108
are those vents in the frieze board? don't want to block your vents. I agree with willie, measure from the top of your door trim to the soffit and see what that measurement is. do you have an overhang, hard to tell from the photo, if so how much is the overhang?
Gary
"You get what you pay for, and sometimes free costs more!"
GBrackins is offline   Reply With Quote
Old 05-03-2013, 03:33 PM   #6
AGWhitehouse's Avatar
Gonna look pretty weird being a stand-off structure with a flat roof below the gutter line. If aesthetics are irrelevant, then you CAN do it, though I don't recommend it. The right way is to tie into the existing roof and re-route the gutter. The fascia of the porch should be in line with the fascia of the house and the porch roof slope shall extend at least half way up the main roof. Maintaining a minimum 3:12 will allow you to still use shingles. Any lower of a slope and you'll need to use a low-slope membrane.
Life's too short...so enjoy it!
AGWhitehouse is offline   Reply With Quote
The Following 2 Users Say Thank You to AGWhitehouse For This Useful Post:
GBrackins (05-03-2013), kwikfishron (05-03-2013)
Old 05-03-2013, 04:07 PM   #7
Here is basically what the house looks like from the side.
There is no roof overhang. House was built in the 30's for a mine and moved to town and put on the foundation in the 40's.
I have no problem with a metal roof to keep the slope low if that would work. I'm on a limited budget and was wanting to cover the deck so I could sit outside and have shade (front of house is south facing).
Thanks,
Old 05-03-2013, 04:15 PM   #8
GBrackins's Avatar
are those vents?
Gary
Old 05-03-2013, 04:16 PM   #9
Yes there is 2 gable vents on each end also.
Old 05-03-2013, 04:22 PM   #10
This was my original thought. If it is not a good thought then I need to change before I start calling contractors in (that is why I asked here first).
Thanks,
Old 05-03-2013, 04:33 PM   #11
This is what the house looked like before new windows doors and siding. Removed the part over the door and from what i'm understanding is I'll most likely have to do the same over a new deck?
Old 05-03-2013, 05:05 PM   #12
GBrackins's Avatar
this is what I'm asking about .....
Gary
Old 05-03-2013, 05:51 PM   #13
Yes those are vents.
Old 05-04-2013, 08:17 AM   #14
Rewards Points: 240
there is a house like yours that i often drive by. it has a porch roof like this one, but much larger. and i think it looks great.
Fix'n it is offline   Reply With Quote
Old 05-04-2013, 10:34 AM   #15
To me it doesn't look like there will be enough room above the door; is there a height minimum in your town? If so, maybe a landing off the door and a one step drop to the new porch and make the deck even to where the siding stops...just a thought. In other words lower the deck height.
peakcelln is offline   Reply With Quote
Miscellaneous deck questions NewHomeDIYGuy Building & Construction 38 09-17-2012 02:41 PM
Building Floating Deck over ground and Concrete slab jagnew Building & Construction 2 05-27-2012 12:10 PM
Kool Deck Restoration Advice JudyR Landscaping & Lawn Care 3 10-14-2009 01:20 PM
need venting advice for a roof deck johnny67 Roofing/Siding 12 05-25-2009 01:38 AM
Deck - 45º spindles - advice wanted (pics inside) Kevin K Building & Construction 21 06-06-2007 10:28 AM
