Deck Pier Shims - Building & Construction - DIY Chatroom Home Improvement Forum
Old 08-16-2012, 09:44 PM   #1
Deck Pier Shims
I'm building a floating deck and have a total of 9 concrete piers that will be hold 3 beams (under a hot tub, main beam in the middle). Two beams will have joists sitting on them and the joists will attach to the main beam and rim joists with joist hangers.
From taking a few measurements and eyeballing, it looks like the piers are a bit low, which I would think is better than high.
Any suggestions on how to shim the beams up to the height I need? Galvanized washers? It's maybe 1/4-3/8 at most. The concrete kind of sunk in the pier more than expected (Quikrete)
Thanks.
OKDrew63 is offline   Reply With Quote
Old 08-16-2012, 10:44 PM   #2
Civil Engineer
Rewards Points: 4,580
You should be using a galvanized bracket such as the type Simpson makes for attaching a beam to a concrete pier. If you are using such a bracket, shimming is very easy, you can use wooden shims, galvanized steel shims, or stainless steel shims. You should post a picture of your pier and beam situation, hard to visualize otherwise.
Old 08-17-2012, 08:21 AM   #3
I'm using the Simspson ABA44 bracket to hold the beams. I'll try to get a pick, but won't be until much later today.
Would an ACE Hardware carry these kinds of metal shims? I'd prefer to stay away from wood.
Old 08-20-2012, 08:32 AM   #4
I picked up some composite shims and got the issue resolved. These work pretty well and don't have to worry about rot.
Thanks.
Old 08-20-2012, 03:13 PM   #5
retired union carpenter
Send a message via Yahoo to coupe
I've been using plstic horseshoe shims. since 1977 for many projects from alucabond panels to keeping Z-bar straight. keep a couple hundred on hand, they come in handy for many things
http://www.amazon.com/s/?ie=UTF8&key...l_2k8m1l6lmz_e
good luck
as always, just my thoughts
good luck....coupe/Larry
take what helps? ignore the rest.
coupe is offline   Reply With Quote
Old 08-20-2012, 03:20 PM   #6
Rewards Points: 121
are these shims appropriate when the concrete itself is slanted slightly?
Queequeg152 is offline   Reply With Quote
Deck Staining Nightmare steven994 Painting 6 04-06-2014 10:10 PM
8" deck pier? quincy Building & Construction 9 04-23-2012 08:31 PM
Pergola over existing deck cpfullback Building & Construction 0 08-04-2011 12:36 PM
Building a new deck....and creative uses of granite scrap in outdoor living space Rhizzlebop Building & Construction 9 05-15-2009 12:17 PM
