Deck Pier Questions - Building & Construction - DIY Chatroom Home Improvement Forum
Old 09-15-2010, 12:02 AM   #1
Rewards Points: 1,062
Question
deck pier questions
1. my legal frost line is 3 ft but i really don't think ground freezes that deep around here (mid-Atlantic). i wanna go with 2 ft pier depth. and if it does have 1/8", i don't really care so much - it's a deck. do you think that is OK and is 12" pier diameter OK if i'm setting 6x6 posts ?
2. should i bother setting some rebar inside my 12" form tube or simply poured concrete will be fine?
thanks
Old 09-15-2010, 12:30 AM   #2
Registered User
Rewards Points: 4,910
Why go to all that work and not even build to minimum Code requirements? Probably wish you did when it heaves.......
Minimum footing size: IRC 2006 Deck Code (minimum safety): http://www.lancova.com/deckinfo.pdf
Only if required on the re-bar.
Other frost heave preventions: http://books.google.com/books?id=1gg...num=3#PPA31,M1
http://rockproducts.com/mag/rock_agg...prevent_frost/
Gary
Old 09-15-2010, 06:57 AM   #3
Frost line for us is 30". But if the deck it attached to the house, footers need to be below frost line. Otherwise, the deck could rise/fall with freeze cycle and pull loose from the house, or damage the house at the ledger. Don't skimp.
Old 09-15-2010, 05:09 PM   #4
Coconut Pete's paella!
CoconutPete's Avatar
Rewards Points: 504
Isn't the inspector requiring a footing inspection? They wanted to check the depth before I poured on mine.
I'm also confused on how you arrived at 2 feet.... why not go 1 more foot and be up to code.
CoconutPete is offline   Reply With Quote
Old 09-15-2010, 09:47 PM   #5
Rewards Points: 502
I might do a floating deck above the frost line, but not one attached to a structure.
forresth is offline   Reply With Quote
Deck Staining Nightmare steven994 Painting 6 04-06-2014 10:10 PM
Deck Questions burnt03 Building & Construction 2 08-08-2010 01:11 AM
Floating deck questions DIYguy2000 Building & Construction 6 04-23-2010 11:59 AM
Leaking deck flashing questions....help! Oxymoron Building & Construction 6 01-03-2010 10:54 PM
Building a new deck....and creative uses of granite scrap in outdoor living space Rhizzlebop Building & Construction 9 05-15-2009 12:17 PM
