Deck Pier Question - Building & Construction - DIY Chatroom Home Improvement Forum
Old 07-24-2013, 10:40 PM   #1
deck pier question
I am building a playhouse and planning on building it on a 2x8 platform on deck piers. Since its a playhouse I am not anchoring it to the ground or anything like that. After my joists are set on the deck piers is it ok to add shims under the piers to level the platform?
markharmon is offline   Reply With Quote
Old 07-25-2013, 08:59 AM   #2
Rewards Points: 12,818
Far better to just set the blocks level.
They need to be sitting on an area that's been dug out to remove all organic matter and back filled with gravel.
Old 07-25-2013, 09:03 AM   #3
Ok as I said this is a playhouse. This is going to be sitting on a concrete pad. So, with that said, what is best way to set the blocks level?
Old 07-25-2013, 09:31 AM   #4
Just take a straight piece of wood that your going to use as a rim joist, set it standing up on the blocks and a 4' level to check it sitting on top of the wood.
If you just set the blocks on top of let's say an old lawn, as the stuff dies under it and rots the blocks are going to sag.
Old 07-25-2013, 10:03 AM   #5
If its not level can I shim under the blocks?
Attached deck question. Bugman1400 Building & Construction 31 09-09-2012 12:11 PM
Under deck question/ ideas sm424 Building & Construction 7 07-03-2012 05:39 PM
Deck structure question houseinthewoods Building & Construction 5 06-13-2010 10:18 PM
Question about refinishing a deck... Ler0y Jenkins General DIY Discussions 11 05-26-2010 10:09 AM
Adding on to my mothers deck question. justariot Carpentry 6 03-15-2009 08:09 PM
